Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
The spring placement for the trigger replacement
I ordered a replacement trigger and cannont determine the placement of the spring
  • 169 Answers
Look at the old trigger and see where the spring has been rubbing. Place the spring around the trigger post and slide it into the trigger housing. With help of a small screw driver or scribe to flip the trailing end of the spring over the stop post in the housing. Hope this helps
Posted on Nov 20, 2009
How is the trigger installed?
The Husky website might provide an exploded view for buying parts. That should help.
OR try Here
http://www.ereplacementparts.com/husqvarna-chainsaw-parts-c-114486_114487.html
Nov 10, 2015 | Husqvarna , No.455 Rancher, 20" Gas -...
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
Nov 02, 2015 | Cars & Trucks
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
When can I order a conical spring for the trigger?
Keep calling the company, somebody has to know where they can get you that 'spring', after all it's the customer service that makes a good company great ! Can you make one for a paper clip or something else, maybe a spring on a clothespin? Keep thinking, you'll come up with something.
Nov 06, 2014 | Microwave Ovens
DeWalt D51823 nailer leaks air and shoots continusously
Common problem with dewalt due to vinyl orings. Simple tests to determine if trigger valve may work before re-installing. With trigger valve in hand, depress the trigger pin and hold. The bottom of the inner spool is visable in the opposite side from trigger pin and should move inward slightly with little effort when you push it (spool should have almost no movement inward before making contact with body of valve ). If the spool moves inward 1/16 to 1/8 inch, most likely the oring is too worn and not making contact with body of valve (when under pressure, this spool is held against body of valve (closed), and will open when pin is depressed (firing pin pushes on the spring and spring pushes open the valve) ). Next take valve apart and pull out the spool (spool should be difficult to remove from lower body of valve). With spool in hand push upper part of spool into the cap, should fit snuggly. trigger pin has two orings. The upper oring should fit snuggly into cap and lower oring snuggly into spool. The two orings on the pin are made of vinyl and fail. Notice that the spool has a small hole at the bottom. If the pin oring s bad air will leak past pin. Replace with 2mmx1.5mm black oring. After replacing the two pin orings, make sure the pin fits snuggle in the cap and spool, if not , replace the whold valve. The spring is usually good, but if rusty, replace the whole valve unless you happen to have the exact spring in good condition. The two outer orings on the body of the valve do not have to be replaced unless cut. Good luck
Dec 23, 2012 | Air Tools & Compressors
My framing nailer shoots out 2 nails at a time
Assuming that you are using the correct nails. This will usually happen if you have bump-fire trigger and are trying to place the gun on the work then pull trigger. Replace the safety spring if weak and bump-fire only (spring should be very firm). If you have single fire trigger, replace the trigger and the trigger valve for good operation. If you have always been bump-firing and now double firing, replace the safety spring and trigger orings. Good luck
Oct 21, 2012 | Air Tools & Compressors
D51850 framing nailer leaks air
Dewalt uses vinyl looking orings that begin to just melt, unlike the black rubber orings. I usually replace about four orings within the gun and two within the trigger. Remove the head and pull out the cylinder by gently prying up on the white cylinder seal. Place the cylinder on workbench with bottom side up. Take picture to the unit or draw diag. with placement of parts. Push down on the spring loaded retainer and remove the oring. The orings that you need to replace are under the white cylinder seal. Larger is 75mm x 3mm (or 74.4mm x 3.1) , smaller is universal oring # 141 (58.42mm x 2.62mm). There could be other failing orings in the head (vinyl orings will look streached out if bad, but do not need to replace of good) . The two orings in the trigger are also vinyl and fail often. Replace with 2mm x 1.5mm or measure because of many different trigger valves (or replace trigger valve, not expensive). Good luck
May 25, 2012 | Dewalt D51850 20° Full Round Head Framing...
The spring in my trigger flew out. how do i put it back
The n60fn uses two triggers, rapid fire trigger (black metal) is pictued with your post and does not need a spring. Just replace the 3 mm roll pin that holds trigger to the body of the gun and you should be good to go. The other trigger is the white plastic sequential. The sequential trigger uses a fine spring between the trigger and centered on the tva6 trigger valve. Parts and breakdown at www.toolpartsdirect.com. Good luck
Aug 23, 2010 | Stanley Bostitch Air Nailer Trigger N60...
1987 MSD Distributor Cap Sparkplug Placement Help
First you need to determin witch one is #1 on cap Witch usely is the one directly behind carb. or throutle body. than its perty strate forward from there rotor runs clockwise. Cap only goes on one way. Food for thought when you chg. cap or wires one at a time is the rule even for a seasoned mechanic.
May 04, 2009 | 1987 Chevrolet Camaro
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
933 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
