Question about Dell Latitude C600 Pentium III 750MHz, 10GB, 128MB, 14.1 TFT, 56K Modem, 24X CD (C600750128) PC Notebook
How do I replace the touchpad on a Dell C600? (The manual doesn't seem to tell this info.) TIA
  • 1 more comment
  • ethveg Sep 04, 2009
    I've been inside befoe, replacing several keyboards (I have 3 of the C600s) so I'm not afraid.
    And I have directions for replacing the "palmrest" outside covering.
    What I'm asking about is the hardware module that apparently mounts on the motherboard. (I assume that the touchpad itself is okay, and that the lack of response when I slide over it is due to the underlying module.)
    And yes, if you can make that info available I'll use it with gratitude.
    TIA
  • Barry Parks May 11, 2010
    Do you have the replacement touchpad, a small Phillips screwdriver, about 30 minutes and an adventurous spirit? I have replaced several of these. It is not difficult, but it is going finding all of the screws to remove and replace. Let me know and I'll try and put a guide together for you.
  • 202 Answers
Thanks for getting back to me. As far as I know, the actual module that the touchpad connects to is part of the motherboard and not replaceable as a sub-assembly.
That said, what kind of issues is the touchpad giving you?
Have you tried un-installing it and re-installing the latest drivers?
The controls for the pad in the control panel are fairly good, too.
Have you updated the BIOS?
Hope this helps, and as before, please let me know.
~ Spoem
Posted on Sep 04, 2009
  • 596 Answers
This part can be purchased on eBay or from any computer store that handles Dell parts. The replacement is fairly easy, requiring you to replace the top part of the keypad section. (Called a lower bezel.)
Good Luck
C2Solutions
Dell C600/C500 user manual
Check the Dell website or perform an Internet search using Google or Yahoo. No manuals here.
May 11, 2015 | Dell Computers & Internet
I need to put re-assamble my dell latitude c600..
The service manual with step by step instructions on how to remove each part is located on Dell Support website
http://support.dell.com/support/edocs/systems/latc600/sm_html/index.htm
Jul 21, 2012 | Dell Latitude C600 Pentium III 750MHz,...
My touchpad will not work at all on my dell latitude laptop
Unless the Dell is fairly new, the touchpad cannot be turned off. If you have a special function key that shows a pic of a touchpad with a line through it, you use that key in conjunction with the Fn key. This combo turns the touchpad on and off.
If it doesn't work, then you may have a faulty touchpad. This means that either the touchpad data ribbon has come unattached or the actual circuits that control it are bad.
Jun 08, 2011 | Dell F3534 Touchpad
Hi. I have a dell c600 and the keyboard and touchpad are not responding when I boot to windows. When I go to BIOS set-up the keyboards work fine.
Plug in a usb keyboard and mouse. Reinstall your keyboard and mouse drivers through the device manager. Let me know if you need help with it.
Mar 18, 2010 | Dell 0Y3740 Keyboard
Some keys on my old dell latitude c600 are not working
it happens, even i have DELL 610 notebook that has some keys not working, the only option is to change the keyboad layout.....
in India all parts can be replaced/repaired but abroad is a different story....the reparing cost is equal to the new....just trash the laptop once it's life is thru....
Dec 06, 2009 | Dell Latitude C600 Laptop Keyboard 47NVF
Touch pad is not working in my dell latituse 600
If the touchpad is not working, then ensure that the touchpad is not disabled in the BIOS, in control panel ensure that is is not disabled there either. If the touchpad is not disabled in BIOS or Control Panel, then a palmrest would be required to fix the issue. On a system of that age, I'd just use a wireless mouse till I was ready to replace the system
Jul 03, 2009 | Dell Latitude C600 Notebook
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Feb 22, 2009 | Dell C600 (002UH) Motherboard
Display problem dell c600
I've also had that, The FN and brightness I've not determined, as I changed LCD panels, however, components in the LCD screen can be swapped out, cable and inverter and backlight (<-very hard to do!!) and the ATI graphics board is mounted to the mainboard, for the C600 they are affordable
Dec 20, 2008 | Dell Latitude C600 Lcd LCD Display
My computer keeps scrolling downward
I had a C600 do the same thing. It kept happening but I got some control over it by blowing around the edges of the touchpad with canned air and then cleaning the touchpad agressively with 99% isopropyl alcohol and a soft lint free cloth. If that makes a noticeable difference then we are on the right track. If the problem becomes unmanageable touchpad replacement may be in order. Let me know if this helps. If you need further solutions I will research further and post as data becomes available.
Jan 06, 2008 | Dell Latitude CPX Notebook
Dell c600 laptop cursor arrow
Hi Buzzy, I?ve had this problem with several C600 series laptops and the problem has always been fixed by reinstalling the drivers for the touchpad/joystick mouse controller. If you are using Windows XP here is the link to the correct driver: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R68445&SystemID=LAT_PNT_P3C_C600&os=WW1&osl=en&deviceid=283&devlib=0&typecnt=1&vercnt=6&formatcnt=1&libid=17&fileid=88809 Let us know how it goes and please don?t forget to rate the posting.
Jan 18, 2007 | Dell Latitude C600 Notebook
Dell Latitude C600 Pentium III 750MHz, 10GB, 128MB, 14.1 TFT, 56K Modem, 24X CD (C600750128) PC Notebook Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
