Question about Frigidaire Dryers
I need to change the power cord to my dryer to fit the outlet in my new residence. Is there any specific order to how the tabs hook to the dryer on the back? They aren't color coded.
  • 304 Answers
Always disconnect electricity before beginning this process.
If you are using a 3 wire cord the wires go exactly as you see them. The middle wire goes onto the middle terminal and the outside wires go to the outside terminals which one goes on which side doesn't matter.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside of the terminal block and I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Posted on Sep 04, 2009
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Jun 02, 2012 | Whirlpool LEB6200 Electric Dryer
I have a lg dryer with a 220 electric hook up plug and in my house there is only a 110 electrical outlet. is there any way I can just change out the cord to a 110 electric cord and use it?
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Jun 26, 2011 | LG Dryers
New house had dryer outlet that electrician installed a Range outlet ( 30 amp breaker) by mistake on the wall. I changed my cord on Samsung dryer to match the outlet and dryer made a loud noise and would...
You still do not have one of the wires hooked up right...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 01, 2011 | Dryers
3 wire to 4 wir
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
I. must change the cable on the dryer to fit the outlet I have
The wiring color code is as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL ( 0 VAC)
GREEN - GROUND
The RED and BLACK combined is what comprised your 220 service to run the appliance. The following link explains this in better detail:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have any questions, please let me know. I hope you find this information helpful.
NOTE: This is for United States Standard Wire code. If you reside outside the US, please let me know. In addition, homes built after the year 2000 are REQUIRED to use the 4-wire configuration to be within standards. If you're home already had a 3 wire outlet installed, however, you do not need to change it.
Aug 16, 2009 | Whirlpool MEDZ600TB Electric Commercial...
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
