Question about 2wire HomePortal 1000 Router
Using 1000SW, I get report of:- Connection Status DSL Signal: DSL found on Line 1 PPP Login: Login successful Internet Address: An Internet address was verified ISP Link: Domain Name Server found Configuration Server Link: Unable to contact the Configuration Server I connect to the net ok but how do I correct the Cofig Server error? David [who is very stupid) TY for reading
    Scholar:
  • 62 Answers
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
spin
Posted on Sep 13, 2009
All lights of the modem are on but there is no internet connection although I reset the modem, turned off everything and unplugged and waited for 6 minutes. Besides, I went to the 192......., put the dsl...
1. Call DSL provider verify service is active. They should be able to ping their DSL modem.
2. If good service, plug your pc directly into dsl modem. If youre able to connect, then the router is bad. Youll need a new one.
3. If I read this wrong, and its the dsl modem that is not connecting, AND the service says its working, then it maybe the dsl network port has failed. In which case report it to your service provider and they should replace the unit for you.
4. You can try to unplug and replug the network cables, all of them. Or try different ones. Its just possible you are getting a poor connection at the wire terminator.
May 24, 2011 | Computers & Internet
My shared internet connection speed is very slow, please help.
Hi,you can check your exact internet speed with this http://www.ip-details.com/ site ,after that take a decision for your internet speed , here only i got my exact download and upload speed .
Mar 03, 2010 | Computers & Internet
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
Assistance with blinking light on my DSL modem
First thing to do is unplug your DSL modem and leave it unplugged for about a minute then plug it back in and see if problem is corrected. If not you should contact your ISP tech support. You could have a bad line from the phone company or bad connection in your house. Also if you have filters installed on your other phones you can have a bad filter that is causing interference and keeping yoiur DSL from working properly. You should go to "Start" > "Run" and type cmd and hit "Enter"
In the command window type ping google.com -t (Enter) This will start a continual ping. If you are getting ping times exceeding 70 - 120 ms that could be a sign your DSL is not functioning properly or if you get packet loss. That is when the ping time doesn't return a time periodically.
Sep 23, 2009 | Westell Wirespeed LiteLine 6100...
Connection to my computer of hp photosmart c6300 via belkin adsl2router
3. Open IE beoswer.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
ADSL Router DSL-G604T
all ADSL routers are very fussy when it comes to power fluctuations, even the tiniest can set them into error, first thing to try, is pull the power cord out of the back of the modem, wait a couple of minuteds, then plug it back it, give it a few moments to re-connect and see how it is, if no luck with that, check the DSL, or ADSL light is on and solid.. if so look on the bottom of the modem for an ip address, open internet explorer browser, type that ip address into the address bar and hit enter, it should prompt you for a username and password.. usually ADMIN for both user and pass.. then go to "status" or "diagnostics" depending on the modem, and it will give you a run down on any potential problem..
PPP error: username and password are wrong (Authentication Failure)
Jun 01, 2008 | D-Link DSL-G604T Wireless Router
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Netscaping
Yes, Netscape 6.2 will work properly with the web page-based interface used in D-Link DSL routers, however, due to problems the browser has loading Java applets and working with Java scripts all of the features may not be visible. Netscape 4.7 does work with the interface, but is extremely slow in loading the various configuration pages. For these reasons, it is recommended to use Microsoft Internet Explorer 5.x or 6.0 to configure D-Link DSL routers. Internet Explorer loads the pages faster and Java applets work properly, as shown below. Note the tree in Fig. 1 (using Internet Explorer), representing the routerĀ“s various configuration pages and in Fig. 2, the PPP Connection information. Using Netscape 6.2 as shown in Fig. 3, the configuration tree is missing and in Fig. 4 the PPP Connection Information is not displayed.
Feb 16, 2006 | D-Link DSL 500 (DSL-500) Router
Open Questions:
2wire HomePortal 1000 Router Logo
271 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
