Question about Haier BC112G Wine Cooler
I have a Haier BC-112g wine cooler that I would like to use as a mini-frig. The cooler temp only goes as low as 45 degrees. For a mini-frig I need a temp in the high 30's. How/can I do this?
  • 2 more comments
  • mrgantri Sep 04, 2009
    I would have to change the cooling "system"? What about just chaning the thermostat?
    I have a Haier BC-112g wine cooler that I would like to us as a mini-frig. The cooler temp only goes as low as 45 degrees, but for a good mini-frig I would need it to hit the high 30's. Is there a way to do this?
    I have a Haier BC-112g wine cooler that I would like to use as a mini-frig. The cooler temp only goes as low as 45 degrees. For a mini-frig I need a temp in the high 30's. How I do this?
    Ps. I'm aware that they're not designed to go below 45 degrees, and that I could pick up a used one for around $30. The issue is that I really like the look of the unit I have and I think it would be a nice project (if it can be done)
    Thank You! You were a great help . . .
    President:
  • 2,777 Answers
Unfortunately to do that you would need a new temperature control and compressor, if it were an industrial sized fridge I'd say go ahead and do it, but for this size of fridge you are going to end up paying more to convert it then you would if you just bought a new fridge of the same size.
If it were me I'd sell the fridge you have on craigslist or ebay and just buy a mini-fridge from somewhere, such as Amazon, free shipping in many cases, and no tax. Here is a great one for example, the compressor would cost you more than this entire fridge:
http://rcm.amazon.com/e/cm?lt1=_blank&bc1=000000&IS2=1&bg1=FFFFFF&fc1=000000&lc1=0000FF&t=dependascient-20&o=1&p=8&l=as1&m=amazon&f=ifr&md=10FE9736YVPPT7A0FBG2&asins=B0000667EE
Posted on Sep 04, 2009
  • 4,472 Answers
These are not designed to be refrigerators they are wine coolers. Their temp range is 45-60 degrees. Just go out and spend 60$ on a mini fridge if that is what you need.
Thank you,
Lee
  • Lee A.
    Lee A. Sep 04, 2009
    Well you definitely have your answer. I hope you'll reconsider accepting my solution.
    Thanks again and have a great day,
    Lee
  • 430 Answers
I don't think that something can be done by you at this moment. You have to change the cooling system compatible with the wne cooler's model and also compatible to the temperature you told us of. Thank you.
  • Nandini Dhar
    Nandini Dhar Sep 04, 2009
    Sir, you can get a new thermostat but be aware that the thermostat is compatible.
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
How to replace thermostat on Haier BC-112G
First lets find out why you want to change the thermostat.
  • The 112G has a control board & temp sensor
If you are having problems try replacing the sensor first then the control board.
Link to the parts breakdown page:
http://service.haieramerica.com/Models.aspx?CID=226#
The sensor is $4.76 & the control board is $26.81.
good luck,
dan
Feb 01, 2012 | Haier BC112G Wine Cooler
The temp is 25 and is stuck on LL
replace the temp sensor first
$4.76 from Haier part# RF-6250-01
still stays at 25 degrees?
replace the control board & you should be done.
$26.81 from Haier part# RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
Haier BC-112G not working
as stated already:
  • first replace the temp sensor: $4.76 from Haier RF-6250-01
Still have the dreaded 25 degree & LL in the temp box?
  • Replace the control board: $26.81 from Haier RF-0668-04
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
119 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
