Question about Cell Phones
I have a problem with the trackball
I can not enter with the trackball however it work good from right to left and up and down, can sombody help me to find the solution because i have changed the trackball 3 times but still the problem continuos thanks
  • flavioigor10 Sep 05, 2009
    i have a blackberry curve 8320 the problem i have is that when i try to click with the track ball nothing happen i mean for example i can move the trackball around all the screen, but if i try to go to call logs, or options and i click on it i can not get in, nothing happen i have to use the botton enter in the keyboard to access insude the funtions or aplications can you help me to find the solution thanks
  • Terry Fritsch
    Terry Fritsch May 11, 2010
    Which phone is it? I can think of about 10 different phones with trackballs
TFT-5600 RKM Trackball not fully functional
Trackball? Think on these computers that there should be a small ring around the outside of the trackball. This ring turns? quarter or half turn then you can remove it and gain access to the inside rollers where the ball sits. Clean the rollers out and then put it back together and ytou should be good for a few more months. then just repeat when the problem gets to bad. Remember this is all "I THINK" Hard to remember back that far.
Dec 15, 2012 | Compaq TFT 5600 RKM - 15 w/ Keyboard,...
NEED HELP SETTING VOICEMAIL.TRACKBALL IS STUCK, GOES LEFT,RIGHT,& DOWN,NO UP.NEED INSTRUCTION MANUAL.
You can download the user manual (as well as other guides) here:
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Tour+9600+Series
If the trackball won't go in one direction, try putting one drop of denatured alcohol onto the trackball and then moving it all around, that should fix it. If it doesn't, lift the trackball up slightly -- very gently -- with the blade of a small pocket knife and blow compressed air underneath it.
Jan 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Blackberry bold trackball goes left, right and down but not up how do I fix this?
This is a common problem on Blackberrys with trackballs. When the trackball goes bad you lose one direction first. Inovagent can replace your Blackberry trackball or you can find another local place to have it done.
Feb 07, 2010 | Cell Phones
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Horizontal hold not working
inside are 2 tiny black rubber wheels one to left and one south of that- clean with alcohol on a cloth 9(not soaked) - I scrap them with my nail going across & you'll see gunk come off. Also turn it upside down & tap it so all dirt inside falls out. wipe all around inside with cloth. Then clean the circle that holds ball. It has to have no dirt on inside area.
Aug 24, 2009 | Microsoft IntelliMouse Trackball 1.0
Trackball not working
you need to have the trackball either replaced or service
Jul 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sidekick trackball won't work =[
More than likely, the trackball on your Sidekick is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol. No dis assembly is usually needed!
Check out the Video at the following link to see how the trackball cleaning on the Sidekick is done
Sidekick Trackball Cleaning Guide
Jul 07, 2009 | T-Mobile Sidekick
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
BLACKBERRY TRACKBALL/KEYBOARD ISSUES
you need to take the phone to a mobile service center and have the trackball service the pins could have alot of dust and dirt on them.
Dec 05, 2008 | Cell Phones
Cell Phones Logo
134 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
