Question about Icom Radio Communications
Icom 756 CI-V computer interface Problem
My Icom 756 CI-V computer interface function stopped working. Rest of radio works fine. The feature did work up until a nearby lightning strike. I did loose some other gear but, once again, all other features of the radio work fine. I used to fix electronic gear, but many years ago. I would prefer to fix the radio myself, if possible. Is this easy to repair, difficult, or somewhere in between?
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Good info posted by Mike Nadeau - N1EQ
Posted on Aug 26, 2017
  • 19 Answers
SOURCE: Ethernet Port failure on Acer Aspire T180-GB7Z
Type of your O.S (Operating System) Windows, MAC, Linux Etc?
Posted on May 12, 2008
  • 121 Answers
SOURCE: My frigidaire es300 self cleaning
sounds like a loose conection at the control
Posted on Nov 29, 2008
  • 85 Answers
SOURCE: Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Posted on Feb 26, 2009
  • 1865 Answers
SOURCE: oven not working
There must have been a fault code that was not corrected, and therefore the feature is disabled.
Could try to press and hold setup key for 5 seconds.
Posted on Apr 16, 2009
  • 2334 Answers
SOURCE: t-touch altimeter stopped working, I suspect it
You may need a new battery, but first check out this site:
Rate me, please.
Posted on Jul 31, 2009
How come my icom 756 pro did not transmitting on 8000 frequency
You have to modify this radio to operate outside of the HAM bands. You will likely find the modification at This is a pretty common and easy modification for HAM radios. Your performance may not be as good as in the HAM bands.
You do this MOD at your own risk. If you are not licensed for operation on ANY frequency or band, you are not legally allowed to transmit. Heavy fines may be levied against you.
Jul 14, 2016 | Icom IC-756PRO Transceiver 002896
Cannot transmitt
The Icom 756 Pro is a very expensive radio. If you bought one and it's not transmitting I really recommend taking it back. It could be anything from the mic, power supply, final transistors, board, anything really. It's going to need to be scoped and looked at in person.
Jun 30, 2016 | Icom Transceiver Ic-756proii
How do I determent the value of resistors/s diode / capacitors ect...... There is no marking on the boards especial in this tiny tiny tiny ones on the Icom 756 radio thanking you in advance Edward Va
If there are no markings, the only way to determine what value they are is to unsolder them and test them. Actually surface mount components don't go bad that often, most likely capacitors, maybe some diodes. They usually do have numbers on them, maybe soldered down side up.
Oct 31, 2014 | Icom Ic-756 Hf Transceiver Service Manual...
Icom 756 transmit but signal meter goes back to zero and showing no rf output.when i key up there is a signal on the built in spectrum i have reprogrammed the radio as stated in the manual but still n
am not 100 sure has have not worked on this model but maybe there is some sort of fuse, "or bulb used as a fuse lie in the old yaesuft-747gx" near the rear output if not loo at the copper tracks on the board around there, and trace back.
Dec 28, 2012 | Icom Radio Communications
I recently bougth 3 Icom IC-F3gs radios, second hand. They all work fine, but i cant access any of the functions on the radio. It is like they are locked somehow. Can somebody help me..... Thanks Wtr
firstly you will need to access the menu if you cannot these may be programmed using the proper software ,you will be able to unlock it then or give it to someone that can program it for you
Aug 25, 2010 | ICOM Informatique iTECH iQfive iQplus Icom...
Configuring audiovox GMRS1072CH walkie talkie
With the issue of 240V if the charger has not a Voltage switch, you will need to find another charger/transformer with the same Voltage/Amps ouput that works with 240V.
For Vox operations, this feature works independly form channel, you should choose the channel# and code # first, to match both radios, and get them communicate, then the Vox feature.
In Some radios the VOX feature works with an external audio accesory, in other radios works with out it.
Basically if this radios works without it, you should see that the radio transmist by itself when you speak direct to the radio, and stops transmiting 1 or2 seconds after you stop talking.
Good Luck.
Nov 20, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Radio Communications Logo
750 people viewed this question
Top Icom Radio Communications Experts
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
