Question about Keyspan USB Parallel Printer Adapter for Macintosh (UP-6CM) Parallel Adapter
Broken key The car is a 1997 Renault Scenic 1.6E. The key for the door is not working. Any advice for how is the key can be fixed or where can we buy a new key.Please!!!
0 characters
1 Points
Brand new lenovo g550 laptop when switched on for the first time didn't display anything on the screen. What's the solution to that? Please help. The processor is running but totally nothing is...
If you have a seperate monitor, turn the laptop off and plug in the monitor to the VGA out on the laptop (somewere on the side of the laptop will be this output). The reason for this is it will make the next steps easier.
Turn the laptop on, you will hopefully get a display from the other monitor. If not you can still proceed, but it will be in the "dark". On the laptop somewere around the Ctrl key, you should find an fn key. If you look at the laptop keyboard you will see small symbols in the same color as this key (usually blue or grey). Look for one with monitors on it, Levnovo's website says that it is the F7 key. Pressing and hold down the fn key, now press the F7 key that has the monitors on it. This should switch between onboard and external and both. release the key and see if either monitor displays. Since laptops alter in the way this key works, you may have to press the F7 key more than once to get the display to switch the display.
More information on this procedure can be found on Lenovo's website:
I hope this is of some help to you.
Jul 27, 2011 | Other Network Devices
Security Key for router, while setting it up.
While settiing up your router always change the security key/wireless key, which is used to connect to your own wireless, please make sure do not keep it as your name or phone number, neither keep it is same as the name of the router.
Best advice is to keep it shot in b/w 10-12 characters, including numbers and alphabets both.
on Jun 06, 2010 | Other Network Devices
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Jul 08, 2011 | Other Network Devices
Error code sc 390 code richo aficio 2045
That error is related to a bed reading in a sensor of the Development Unit, called "TD sensor".
You can try to take out the development unit and see if there is dust of toner or even if the plug is broken.
The development unit is placed under the PCU.
Open the front door and you will see it.
If you can not see anything abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
Jun 02, 2011 | Other Network Devices
Hi: I buyed a FLUKE 5100B used (eBay). I press the keys for 5DC.V.No volts output.
It looks like you have a faulty unit.
Is the 5 volt output the only voltage that does not work?
Mar 23, 2011 | Other Network Devices
How do I program my laptop to work with the vga cable
Your laptop has three video-output options:
* output only to internal screen
* output only to external monitor
* output to both
Look for a 'FN' key on your keyboard, and some extra engraving on one of the 12 "Function" keys.
Press and hold down the FN key, and press the correct Function key, to toggle through the above 3 modes.
Jan 16, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
No. 5 input does not work. Line or mic input. Any advice on who can fix it. Does it have to be sent in or could a local electronics guy fix it?
If there is a warrenty then try with local dealer. If there is no warrenty it seems that local electronics guy can fix it.
Aug 14, 2009 | Motu 896HD
Does Fixya give a good return for your time?
Hey Richie_asg1,
I feel like if you enjoy helping people fix their problems then FixYa is a good use of your time. As far as me I just love photography and cameras, and like helping people find solutions to their problems!
Go Ahead. Use Us.
Jun 11, 2008 | Other Network Devices
2002 Pontiac sunfire running lights
Had similiar problems with my 2001. Check the entire length of the headlamp wiring harness under the hood behind the grill. They are prone to corrosion from road debris etc. Peel off the tape and follow thw wires. I'll bet there will be a broken one. Pay particular attention to the pink one. Just clean up the broken one and fix it with a **** connector and you should be good to go. Hope this helps.
Feb 17, 2008 | PCI Post Diagnostics Test...
Keyspan USB Parallel Printer Adapter for Macintosh (UP-6CM) Parallel Adapter Logo
35 people viewed this question
Top Keyspan Other Network Devices Experts
 C. Dante
C. Dante
Are you a Keyspan Other Network Device Expert? Answer questions, earn points and help others
