Question about Craftsman Garden
I need a belt diagram for the pulley system on an older craftsman 1036 model #917255279
  • 389 Answers
Go to www3.sears.com , put in your 917.xxxxxx model number and you will get everything you need to know about it
Posted on Sep 14, 2009
Drive belt diagram model 917-276051
the closest thing to a "drive" belt diagram would be in the owners manual http://www.manualslib.com/manual/487688/Craftsman-917-276051.html?page=38#manual
the horizontal (front) end would be to the pulley at the engine that the deck belt(s) are not attached to. There is a set of mid pulleys where the direction is changed from horizontal to vertical for attachment to the transaxle.
Jul 01, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Diagram for craftsman 15 gal. 31/2 hp air compressor -no model number ,i need to order new belts
Do not bother with diagram, remove old belt and go to hardware/car part store and tehy will find what belt you need and replace it for you.
If original belt do not exist, with bit of string or pliable old garden hose measure total lenght of the belt, measure and write down belt pulley groove width and depth, and on base of that one car place or hardware store will be able to find you suitable belt.
Hope this will solve your problem
Aug 14, 2010 | Craftsman Air Tools & Compressors
Need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a belt diagram
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.273638&pop=flush Enter your model # and search, scroll down to mower deck, and there ya are.It's an easy one. Straight across the back between the blade pulleys, then to the inside of both idler pulleys, then to the engine pulley. Hope this helps. Dwain
May 23, 2009 | Craftsman Garden
Garden Logo
249 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
