Question about Craftsman 25cc Gas Line Trimmer
How to load trimmer line - Craftsman 25cc Gas Line Trimmer
    President:
  • 1,126 Answers
Http://www.managemyhome.com/mmh/owner_manuals/search/product.Attachments%2C%20Line%20Trimmers:Weedwackers?query=Craftsman
If you know your model number, you should be able to locate the owners manual here....hope this helps.
Posted on Sep 04, 2009
How to load string into trimmer head
pull head off cut 1 piece of line bout 48 inches should be a **** in center of head put center of line in slot then roll line in same direction in both slots lock ends in head reinstall
Jul 15, 2012 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
How to load spool
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hyh
Jan 30, 2012 | Garden
Dont know how to load the line, unable to get the part off to load the line
Here is a video on 3 different heads. Yours is probably the first head that he demonstrates:The only thing that is not demostrated is a left-hand vs. right-hand trimmer. The spool retainer may twist off in the opposite direction if you have a left-handed trimmer.
Good Luck!
Jim
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
Trimmer head line loading instruction
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
While trimmed is in use, how do I release more trimmer line?
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Oct 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Load new line onto the mighty vt26 17" curved trimmer
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman 25cc Gas Line Trimmer Logo
564 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
