Question about Kenmore Dryers
Model#110 65964401 How to properly clean all lint out of unit.
  • 304 Answers
Place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to cleaning all the main components.
The heater is on the right and the motor on the left behind the ducting. A thorough cleaning requires removal of the front duct which is the area below the lint filter. It also includes carefully cleaning the motor, including both ends, of lint to reduce heat retention in the motor windings. Don't forget to clean the vent that penetrates the wall. Airflow problems are often caused within the areas you can't see and should be checked and cleaned yearly.
Reverse the above process to reassemble unit. Good Luck.
Posted on Sep 04, 2009
Testimonial: "just what I needed thanks"
How do I remove the entire lint unit to clean?
Can you get a long magnet to fit in and fish out the screw driver? Or bend a clothes hanger into a small hook shape enough to hook the screw driver .
Jan 17, 2015 | LG Tromm Control Panel AssembFront Load...
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Splendide WD2100XC - The vent from machine to outside keeps plugging with lint. I cleaned it once - having to haul out the unit to do it, which was no easy task - and, now, within a few months of cleaning...
Maybe fan is not working properly, or restricted vent in the first place, causing it not to flow properly and lint gets hung up. Is vent hose fairly straight or does it go around a lot of curves?
Sep 07, 2011 | Splendide 2000S Vented Washer/Dryer
Lint filter light goes on; vent unattached so no blockage and lint screen is clean. Thermostat? Temperature regulator? Model 3510 - about 6 plus years old
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes, I mean if you have not done this already. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the Thermal fuse that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 15, 2010 | Bosch Axxis WTA 3510 Electric Dryer
How do u know if the heating coil is bad?
If you are feeling any heat at all when you place your hand by the air vent in the back, your element is at least partially working. We must determine if your model has a single or double element. If you have a double, perhaps only one side is working. To determine this, I will need the model number located under the lid or on the back of the unit.
If you have NO hot or warm air, it may be your element or the thermal fuse. Need model number.
But before we do that...
The most common cause of this is just a simple build up of lint. No matter how well you clean the lint filter during use, lint does build up and may require cleaning every few years or so. If you do have some warm or hot air and it seems to take two cycles to dry your clothes, try these simple checks (unplug dryer):
1. Insure that your vent hose is not clogged with lint. Unhook it on both ends and see if you can see through it. If there is a blockage, remove lint, reconnect and you should be fine. 2. Insure that the flaps on the vent outside of your house are free of lint and can open and close freely. If they are upstructed, clean. If they do not open or are bent, you may need to replace the vent. 3. Pull out your lint screen and see what you see? Lint build up? Take a coat hanger and bend it to stick into the lint trap well. Can you pull out any lint? Pull out as much as you can. Also look into the vent on the back...is there lint inside? Use your hanger. This may involve opening the top of the unit, or pulling off the front to clean. But let's get the model number before you get that far.
Write me back with model number or let me know if cleaning the hose and/or vent help. I look forward to assisting you.
Aug 02, 2010 | Kenmore Dryers
I am unable to find the vent that leads from the lint screen to the back of the dryer, I am using a narrow vaccum to clean it out, but it keeps getting caught on something. Is there not a clear path, if...
no i dont believe their is a clear path. depending on your model it may bend in the rear back.if your filter is on the front of the dryer when u open the door then the vent bends to the left but their is a blower wheel u are probably hitting. can go through the back and get most of it after u have cleaned out the front. if your filter is on the top then you can only clean so much. the unit needs to come apart to clean it out properly.
Oct 07, 2009 | Kenmore Dryers
Same Problem.. not able to find the lint filter on EWD1477
Lou, thanks for your answer, but I think that the original question is to do with the 'mysterious lint trap' that is mentioned in the manual but isnt actually a part of the machine (ie, its a typo / incorrectly edited manual - copied from another model)
The thing we are trying to find is the lint trap for the condenser unit, which is not the same as the drain pump/filter/trap on the bottom right of the unit (or, at least, shouldn't be - if it existed).
I think this model has a specially designed condenser unit that somehow cleans itself from the action of the washing clothes (in your next run), and flushes the lint from any previous drying cycles away with the rinse water during the next wash.
To help keep things clean, you could try to dissolve or at least break up any gunk buildup inside your machine (likely if your not using the 95 degrees C wash temp setting) by using lots of concentrated bleach (at max temp). However, this could damage the machine, but in my experience it is OK. I am not a employee of electrolux nor am I a service person :)
Jun 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
''clean lint filter'' light is on- dryer will not work
is the door trigger working properly if its faulty then the dryer will not work
Jun 05, 2009 | Dryers
Kenmore dryer 10+ years old model 86376100 63761
Make sure that the lint vent is attached properly to both the outside wall and the dryer. Also make sure that it did not get a hole punctured in it either
Feb 13, 2009 | Electric eBay offers you smart deals and...
Dryers Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
