Question about Samsung SGH-D900 Cellular Phone
If a cell phone is plugged in and you answer a receiving call, could the phone cause current of electricity and burn the person, and kill him?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
Certainly no, because the adaptor u r using to charge any cell sends only 6-9 volts to cell for charging. this 6 volts cant harm even a child
Posted on Sep 04, 2009
My electric Bosh cooktop is humming when the element heats up. Is this normal?
If the noise is emitting from the element the most likely cause is a bad connection where the element plugs into the receptacle. You are likely hearing the voltage/current sparking/arcing between the terminals of the heating element and the prongs inside the element receptacle. When this happen it will require replacing the receptacle and the element because it will burn off the contact points of where the two touches to make the connection. If you just replace the element and not the receptacle too, it can cause the terminals on the new element to burn out. Perhaps get a qualified person to have a look at it - it just may need a service...
May 07, 2017 | Cooktops
My phone screen is frozen. I receive incoming calls but can't answer them. Phone battery is not removable. How do I fix this?
Try To kill the battery in the phone and once it is dead try to turn it on a couple times with out the charger plugged in then plug in the charger for about 5 min while the phone is off and try to turn it on again and see what happens.
Apr 29, 2016 | Cell Phones
Help
please clean the cell phone you only have to open
May 07, 2010 | Samsung SGH-S5230 Cell Phone
How do I check voltage on the flyback?
If you Don't know...
Then you should NOT even attempt to measure it!!!
YOU CAN EASILY BE KILLED!!!!
THIS VOLTAGE IS NOMINALLY IN EXCESS OF 30,000 VOLTS AND WILL KILL YOU!!!
Oct 10, 2009 | JVC AV-65WP74 Rear Projection Television
No spark 110cc engine wont start
Check the fuses. Next, check for spark but with a new spark plug. How good is the battery? If needed, add water to the battery cells enough to cover the top of the cell plates.Try a jump start from your car battery. Is the kill switch on? Check the operation of the ignition switch with a volt ohmmeter. You should be getting power into and out of the ignition switch.
If the bike doesn't start and run properly check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. Broken or out of adjustment, it would kill the spark. Check for a broken wire at the switch or coupler. Get a service manual and check out the electrical section. Some bikes have a diode integrated into the turn signal relay. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. If that doesn’t work, check out the relay.
Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing.
Please rate this answer. Thanks
May 28, 2009 | 2000 Honda X- Eleven
When i receive a call i answer but the person can't hear me
your phone needs a calibration. if your phone is in warrenty, go to your local shop.
May 15, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Cannot receive faxs
The majority of non receive issues are phone line problems.
3 conditions must exist for a fax to receive, the phone line voltage must be high enough, the phone line current must be high enough the the DB gain must be correct.
A fax receive should be viewed in the same way a remote controle works.
When you send a fax, you manually access the phone line when you select send, you connect to the phone line, normally via a relay. Once that physical connection is made, it can send anything. Maybe not well, but it will send.
Where as receiving is an electrical signal that activates the machine. If your phone line is not up to standard, its like haveing a remote control with weak or dead batteries and trying to turn on your TV with those weak batteries in it.
Issues, simply a bad phone cord between the machine and phone jack. Some resistance may have acrured over the years. The phone jack itself may have a poor connection.
A staticy phone line will cause a fax not to pick up. Plug a phone into that line and see if there is any noticible static.
Multiple devices plugged into the phone line with the fax machine. ETC an answering machine, credit card machine, etc can cause more of a draw on a shared line, if that is the situation, at least for a test, remove everything but the fax machine from the line and see if it receives then.
Rarely if the machine can send and not receive is the machine an issue.
Have your phone lines checked well and that sould resolve the issue. And make sure the line is not plugged into the extension or phone jack on the machine, but plugged into the line jack. That is also a common problem.
Apr 30, 2008 | Office Equipment & Supplies
Headset
it might be that the speaker/buzzer of your phone is already busted or perhaps just a lose connection. Let a phone technician inspect it. It can also be that the phone is locked to its headset state, this means that the phone always reads that the headset is connected, in this case just restart your phone. Be sure to check also if the profile is not set to headset. These are the possible causes i assume but i think its more on the hardware problem.
Please Rate Thanks
Jan 08, 2008 | Nokia 3200
NOKIA 1600
see budy if u are not getting the name of that person than u have to first add the name of that person in ur contact list,,,,,,,, and if at all u are not getting the Number of the person calling u, than it is surely a software problem than u have to confirm from the vendor itself.
Oct 24, 2007 | Nokia 1600 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
66 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
