Laptop dvd drive door will not open
I can not open my Compaq laptop dvd drive door any clue how to open? I have removed the drive from the laptop ( toshiba model sd-r6252 ) one day my driver got messed up. My dog wacked it,while it was open,and ever since i have had to press thew button and use my fingernails to open it all the way. It was sometimes hard to put the drive back in like it might stop halfay and u have to push it the rest of the way. Any way one day when i did it a little metal bar slid out. I have figured out where it goes. 1.i cant figue out how to get it all the way on there 2. i opened the case once but cant figure out how i did it.
  • Anonymous Mar 12, 2014
    How does the dvd drive open? I have been trying to open it for the past 3 hours. There isn't a button and pushing along it does nothing to open the drive...Help!
  • 21 Answers
If you cant open the rom drive, unravel a paperclip and stick 1 end into the tiny hole on the rom drive.
if you get tired of doing this you have 2 options
either take it to a local repair facility or buy a new drive and install it yourself
Posted on Dec 08, 2007
How to remove the DVD drive
Turn off and unplug the laptop, some where on the bottom of the laptop will be a single screw, about 5 inches from the DVD drive edge of the laptop, remove it, it may be a long. Once that is removed, open the drive's tray, using a paperclip (stick it into the "very small hole" in the front DVD drive draw, and press it in slowly...) the door/draw will open. Grab the door/draw and slowly pull out, IF it doesn't come out, you may have removed the wrong screw... try again.
Jul 17, 2012 | Toshiba Satellite A65-S1065 Notebook
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
I have a compaq presario cq 60 laptop with Vista - i don't understand how to access the CD-ROM drive - I would normally expect it to appear as an additional drive using the Explore function, but I can't...
Normally it would show up in "my Computer" as a drive, if it is not, then the computer is acting like it is not installed or not enabled. Go to the device manager and look for the dvd drive there and see what the properties say. Put the computer on its back and with a small phillips screwdriver, remove the screw that holds the drive to the motherboard. Now flip the laptop back on its feet and insert an open paperclip into the small hole in the door of the dvd drive bezel, this willphysically trip the door to open. Pull the door and tray out and keep pulling and the rest of the drive will follow. Power up your laptop with the drive missing and access "My Computer" and see if anything changes. Now,power down the laptop, remove the battery....wait 30 seconds and slide the drive in and make sure it seats all the way in, replace the hold down screw, replace the battery and power it up. Let windows recognize the drive and load drivers for it. If it does not read the drive, there may be an issue with either the interface on the drive or the socket on the motherboard.
Oct 04, 2009 | Compaq Presario CQ60-220US PC Laptop
Replace dvd drive on eMachines laptop
I have removed this drive from my M5414 by removing the bottom case screw that is in between the battery latch and the Left edge of the DVD drive door as you face it. The trick is getting a hold on the drive to remove it AFTER THIS SCREW IS REMOVED.
I solved this problem by opening the drive before shutting down the computer.
Next remove the battery.
Now remove the bottom case screw between the battery latch and the left corner of the DVD drive.
Now since the door is open you can extend it all the way and grab INSIDE THE TRAY, NOT THE FRONT BEZEL, and gently pull it straight out.
Be patient, you may have to wiggle it slowly and gently left to right, you will feel it loosen, and notice it move forward. IF NOT, DO NOT FORCE IT.
Apr 05, 2009 | Computers & Internet
How can i replace my cd to a dvd in my compaq lab top
You'll have to order a drive for your model of laptop (either from the manufacturer or from ebay), and have it installed. Most of the drives in this style of laptop are held in place by a single screw. Power down the laptop, remove the retaining screw, remove the old drive, install the new drive, and replace the screw. Windows will detect the new drive automatically, and then you can install the DVD software. Keep us posted and good luck.
Mar 07, 2009 | HP Compaq nx6110 PC Laptop
How to remove the optical drive from a Compaq Presario 3045US?
Open the RAM door and remove the two screws underneath. The optical drive will slide right out.
Jan 11, 2009 | Compaq Presario 3045US Notebook
How to replace the cd rom in laptop with a dvd-rw
laptops are very tricky to open...it is much better to look for a nearest compaq support center and have it checked by their own technician.
Aug 06, 2008 | Computers & Internet
update the firm ware for this drive if that is possible. This will rewrite the eprom data and hopefully restore lost functionality.
Feb 11, 2008 | Computers & Internet
There is a tiny hole on the draw in which to insert a paperclip to manually eject the draw.
Jan 16, 2007 | Compaq Presario X1000 Notebook
Computers & Internet Logo
364 people viewed this question
Alun Cox
David Payne
David Payne
