Question about Starbucks Saeco Italia Digital Barista Coffee Machine
SUP021 YR keeps getting clogged
Our Saeco Italia SUP021 YR doesn't produce expresso. We put the beans in, push the button to make a cup, but it won't come out. Why does it clog up so much? We've tried about 6 different brands of beans (haven't tried the brown beans yet).
    Sergeant:
  • Starbucks Expert
  • 223 Answers
If try a lighter bean before doing anything else. Sounds like you were using something very dark. Small grinders do not like super dark beans..
After that you can try to clean the grinder using these instructions.
Saeco Italia Grinder Cleaning Instructions
You may also consider replacing the grinder burrs if the machine is old, and they have never been changed before.
Grinder Burrs Conical for Saeco Gaggia
Posted on Jun 03, 2015
  • 80 Answers
Go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Posted on Sep 04, 2009
Hello- I have a Saeco Italia machine, about 4
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Sep 27, 2009 | Coffee Makers & Espresso Machines
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Machine won't return to the home position
Hi
2 things.
1. You may have a broken brew drive.
2. You may have a brew drive that has jumped its micro switch.
Call a service center
Apr 23, 2009 | Starbucks Saeco Italia Digital Barista...
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR how to clean metal filter?
The item you were refering to is: http://cerinicoffee.com/Saeco_Brew_Group_key.asp
It is used for removing the screen on brew groups: http://cerinicoffee.com/saeco_vienna_brew_Group.asp
It connects to item #4 below.brew_group_vienna5.jpg Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia sup021 coffee dispenser stuck problem
Hi
Open the front door. Remove the driptray. On the left back side of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out call a service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press" button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between. these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First
you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Done
Apr 25, 2008 | Starbucks Saeco Italia Digital Barista...
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
315 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
