Question about Necchi 3102 Mechanical Sewing Machine
It has gotten very noisy like something is striking something inside.
  • Necchi Master
  • 1,388 Answers
Remove needleplate and clean out lint, broken needles etcalso from around bobbin case area.
Posted on Sep 04, 2009
Testimonial: "I did as you said, also ran the machine without the bobbin race & it was quiet so I cleaned that very good and it solved the problem. THANK YOU!"
Needle on my Singer Simple acts like it is hitting something when fabric is in machine with foot down. Take fabric out and needle passes through.dont know what to do
Install a brand new needle and see if that takes care of it. A bent/damaged needle could strike parts of the machine.
Feb 05, 2018 | Singer Sewing Machines
Singer 2001 needle strikes something in bobbin compartment on down stroke
needle /hook timing is out
take it in to any service center to have it reset
Dec 29, 2017 | Singer Sewing Machines
Machine is bending needles!
First, check the owner's manual to make sure you are installing the needle facing the correct direction. If that isn't the problem, take it for service. This is a dangerous situation. The needle is striking something that it should not. Eventually, the needle may break and flying bits of needle are a hazard.
Dec 16, 2017 | Sewing Machines
Machine is making a loud knocking noise. Bobbin case cleaned, all lint removed and machine greased but still very noisy.
Suggest taking it for service. Could have something that is loose or out of adjustment.
Jun 17, 2017 | Sewing Machines
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
Machine is noisy; top thread breaks, even though needle has been changed out (it seems the thread gets caught on something inside the top)
check to make sure the thread is not winding around the spool pin
also check & see if it's getting caught on the notch on the thread spool
the thread could be coming of the thread take up lever
Aug 10, 2010 | Elna Quilter's Dream 6003Q
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Feb 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Nov 04, 2008 | Janome Memory Craft 5700
Necchi 3102 Mechanical Sewing Machine Logo
176 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
