Question about Epson Stylus CX4600 All-In-One InkJet Printer
Printer wont print
I have put in new inker twice now and it alway sayes empty I have disconnunted everything from the printer and even deleted the printer and reinstalled it I have worked on this for 2 days and I about ready to throw it it only 3 year old and it was printing just fine a week ago before the ink ran out
  • Anonymous Dec 10, 2007
    Printer won't print. I checked the Print Head Nozzles and put in new ink, ran the Cleaning head several times and it still doesn't print anything when I test it. It used to work fine till I was out of town for 2 months. Now it won't work. Help.
  • Sal Baset Dec 16, 2007
    It have 12 printing pending. I change the ink cartridge but still not wrking.
  • Epson Master
  • 1,113 Answers
Are you using Genuine Epson Inks??, if you get 3 years out of a printer these days you've done well!,
Posted on Dec 08, 2007
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
Jan 25, 2012 | HP DeskJet F380 All-In-One Printer
Printer will come on but will not print....nothing happerns.........just put in new black cart does it have to have a color cart to work ( one that has ink in it) because I was only want to use black
I think it needs both, even empty. You could always try to go to the control panel and delete the printer and then re install it using the disc. Sometimes works but slow.
May 30, 2011 | HP DeskJet F380 All-In-One Printer
Orange exclamation point is blinking, screen says "replace supplies", but it says that all the time. Nothing will print or copy. It will scan the document like it's going to copy, but then just stops....
I'm a tech on that printer. That's a generic message if one cartridge is at 0%. When one toner or drum reach 0 it wont print even though you don't use that supply. The unit should show the level on the screen, if one is empty replace it.
Aug 04, 2010 | HP LaserJet 2840 Printer
I have HP 6540 ...... the black cartridge was emptry ( my son do this :) ) ...when i refill it (and put it in the printer) indicator says that the cartridge is empty. When i pres the buttons on the printer...
each cartridge has its unique serial number,
printer remembers him,
is absent sensor of the ink level determination in you cartridge. You can to print, but message will say to you "EMPTY CARTRIGE".
this warning function can be disconnected by you in printing driver.
If you bathe new cartridge, that level will show full.
If afterwards put(deliver) old , that he will show that empty.
Printer can have a memory about two or three last cartridges.
Dec 17, 2009 | HP DeskJet 6540 InkJet Printer
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Empty cartridge indicator, yet cartidge is new
I seem to recall that the owners manual says that is the indicator that you need a new printhead... happened to me, I replaced the print head and problem solved... it's been a while; check the manual to be sure.
May 05, 2009 | HP Business Inkjet 1100d Printer
Ink was low I put a new cartridge in still says low wont print.
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
BrotherMFC-235C status monitor shows ink is empty,but its new ink,and wont print
we called asus and we had to delete a filter in the main program.problem now solved.
Sep 26, 2008 | Brother Office Equipment & Supplies
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
246 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
