Question about Echo Garden
Gas is leaking from the leaf blower.
Gas is leaking from our Echo leaf blower.
  • Anonymous Mar 12, 2014
    Echo back pack leaf blower gas tank leaking where can I have this fixed
  • 279 Answers
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
Posted on Sep 04, 2009
Gas leak on blower
You need to take the carb apart and make sure the needle and the seat is not sticking. It sounds as if the seat valve is not going back into place and allowing gas to continue to come into the carb flooding the engine. Hope this helps.
Aug 11, 2015 | Echo Garden
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Apr 24, 2014 | Echo Pb-251 Leaf Blowers
My Echo PB-251 leaks gas out the exhaust when stored, becomes flooded and hard to start.
well 1st thing with the amount of alcohol that's in gas now days it's no longer a safe/good idea to store even for short time power tools with fuel in them , second are u sure its coming from exhaust or maybe near there ? reason I ask is that maybe there's a fuel hose that's leaking and it runs out near there , this needs attention as fuel could continue to leak out when tool is in operation as well , leaking hoses are a very common problem in todays power tools , from a 600 hundred dollar huskavarnia to a 40 dollar echo none of them make fuel hose they all buy them (probably from same place)
Aug 30, 2011 | ECHO, Inc. PB-251C Handheld Blower
My echo pb2100 gas leaf blowers pull cord is loose and will not recoil
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Sep 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Sep 21, 2009 | Echo Garden
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
401 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
