Question about Compaq Presario 5000 PC Desktop
Connect laptop to cpu and use laptop as monitor
I have a laptop and a desktop - my monitor is old and huge - I want to utilize my laptop as a monitor for my cpu as well as a laptop. Can I network, hub???
compaq presario laptop and desktop
If your laptop has tv tuner & your desktop has tv out you can easily conect the two.
Posted on Jul 07, 2008
    Sergeant:
    Champion:
  • 362 Answers
You can if your laptop has a fire wire plug in if so connect the 2 and if you have windows xp it will walk you through the process to get it started you have to set it up to work with a remote .
Posted on Dec 08, 2007
Apple MacBookPro 2010 is in a white screen
If the start up sound plays and the hard drive sounds normal try connecting the computer to an external monitor. If the external monitor shows the desktop just fine then the cable connecting the laptop to its screen is probably going bad.
If the computer will not boot at all try zapping the PRAM by
  1. Pressing the power button and then command-option-p-r before the gray screen comes up.
  2. Hold those keys down until you hear the startup chime.
  3. Let go of the keys and let the Mac reboot.
If that doesn't work try booting from an install disk and run a repair utility.
Jan 28, 2014 | Apple 13" MacBook Notebook Computer ...
I have change my old CPU intel Celeron D 3.06Ghz to intel dual 2 core but my pc no display my pc is power on my monitor is power on also. The CPU fan is running slower then old CPU . My motherboard
is the monitor running through a vga connection? sounds to me like the mobo is bypassing the connection your using and sending your video signal elswhere. did you change any settings in the bios? try other video outputs to get the screen on then go into bios settings and change the video output to a connection your familiar with. help is here if you need it :)
Nov 20, 2012 | Computers & Internet
The monitor does not turn on. Thank you.
check the power cord connections and the COM port if its connected properly to the CPU or Video card slot.
or try another monitor to be able to see if your old monitor is damage.
Jun 06, 2011 | Computers & Internet
How to connect a extra cpu to acer extensa 4630z
please connect the external monitor and to do these steps "Desktop --> Properties --> Settings --> Advanced --> Utility Manager --> Driver Mode Settings --> Under Driver Mode select Multimonitor option from the dropdown list" .
Press "Fn plus F5"
Aug 05, 2010 | Acer Computers & Internet
My pc lights and fans work, but the screen shows nothing.
Check everything you need to check.
Follow the following tips and guides.
  1. Check if your computer monitor is tightly connected or rather properly connected to the CPU.
  2. If it is connected properly but still doesn't functions, try plugging another monitor and see if it lights and works.
  3. If the other Monitor runs then the old monitor is your problem. (maybe the problem is the cables or the tube itself.
  4. As for me, i advice you to use a monitor which gets its power from the CPU. (the power cord of your Monitor is not a plug but rather a connection from Monitor to CPU.)
If you have other questions and concerns regarding your problem and the guide shown above, feel free to update this post.
If you also need some drivers, kindly update me.
Apr 02, 2010 | E-Machines T3958 (827103050974) PC Desktop
I have laptop. & monitor with CPU.
I had this same problem, but I could find no solution. There are some companies that make a device that would work but they cost far more than a new monitor. Sorry.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
My monitor doesnt work while my cpu does
Try connecting the monitor to another desktop/laptop, to see if the monitor still works.
Try connecting another monitor to your computer,
to see if the video-card on your computer is producing any output.
Feb 02, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
How to connect a cpu to the laptop
There is no way you can hook up your CPU to your laptop monitor. Sorry to say. You will need a replacement. Goodwill? eBay? Friend? Yard Sale?
Nov 10, 2009 | Computers & Internet
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
422 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
