Question about Dell E176FP 17" LCD Monitor
When I power up the monitor the screen flashes for a second or two then fades. Each time I press the power button the same happens, but it wont stay on.
    Scholar:
  • 53 Answers
Check all electrolytic capacitors and replace those which have rounded tops due to overpressure from inside.
If they are all fine, then problem might be related to old CCFL lamps. You may try to disconnect flat cable from processor board, high-voltage wires from inverter, and cable from front controls. Then take chassis and display apart. On the back side of display, where high voltage wires goes inside, there you will find tiny philips-headed screws. take them off and carefully slide backlight lamps off the display. Check if there contrast black rings over the lamps near to electrodes. If you see some, those lamps must be replased, but meanwhile you can substitute those with 27 pF 3kV capacitors, soldered right over pins of connector on the inverter board. Check if that will make the rest of lamps work. Total brightness will be less, but until you find replacement, the monitor will work.
If CCFL lamps was good (no black rings, no darkened areas), then you may face problem with MOSFETs in primaries of backlight transformers or high-voltage capacitors in secondaries.
Posted on Sep 09, 2009
Try a different monitor, isolate to monitor. Then access manufacturers web site.
Posted on Sep 04, 2009
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Monitor will not stay powered up
It is possible that the monitor is going back into "Sleep mode" meaning it is not detecting a valid signal from whatever device it is plugged into. I would try replacing the cable that is connecting the monitor to the PC or Console. As a trouble shooting step try pulling up the "Menu" on the monitor itself by pressing the "Menu" button on the front panel of the monitor, if this does come up then we can say that the LCD itself is most likely working.
Nov 10, 2012 | HP Compaq WF1907 19 LCD Monitor
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
My averatec lcd won't stay on
Can you try your monitor on another computer to see if it does this there as well? Usually this happens only when video is not detected coming from the PC. It could be as simple as a short in the monitor cable. If you have it connected to a laptop you'll also want to check you control panel power setting rules and then the screen saver under display.
Apr 14, 2010 | Averatec D1133 (D1133AH1E-1) PC Desktop
My i phone went blank. did not come up. I put the charger on it and still nothing. after a few minutes it came on but it stays locked. you cant power it down or nothing. the time does not change it stays...
Try performing a "hard reset"
Press and hold the home button (round one on the front)
Press and hold the power button (on top of the phone) so you are now holding both buttons.
If the "Slide to power-off" comes up, ignore it and continue to hold both buttons for 5 seconds.
Keep holding until the phone fades to black.
Wait 5 seconds, then press the power button until the Apple logo appears.
That should reset your iPhone.
Jan 12, 2010 | Apple iPhone 3G Black Smartphone
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I-Inc iF191D wont stay on
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is :
www.ccl-la.com/badcaps.htm click on the link at the bottom for monitor repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 24, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
It wont turn on
Sounds like water damage but try this......... 1) press the * and # and Power button all at once - if the screen fires up with a black screen and some info - then you can flash the phone and hopefully recover it; 2. If the above works - you need to find a flash file and the software to flash it with Good Luck
Aug 01, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Dell E176FP 17" LCD Monitor Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
