Question about Philips 42PF9731D37 42 in. HD-Ready LCD Television
Lcd has no picture has sound
Fpe3000 has sound but no picture
  • 43 more comments
  • hselrahc Dec 12, 2007
    Tried vcr input and cable tv input with same black screen. Sound is OK. Get no response from Olevia web site customer service.
  • celder Dec 12, 2007
    Same thing here, worked perfectly but now it has good sound but no picture just a black screen. Where can you find support for these things.
  • rorock Dec 14, 2007
    Akai LCT3201TD 32 in. LCD Television TV/DVD Combo
    has sound from cable box, but no picture. Can not even get menu buttons on side of TV to activate menu and display on screen. Screen is totally black
  • jaynewaldo Dec 17, 2007
    Hi
    Mine also has a black screen for no reason. Sound working fine. Any suggestions?
  • Anonymous Dec 19, 2007
    I have the same problem.
  • csowalker2 Dec 21, 2007
    i have the same problem
  • ito1 Dec 31, 2007
    same problem but the picture does flash on for asplit second when the on off button on the front is switched on.
    this indicates the backlight is working but perhaps the power supply may be faulty. I have dismantled the whole thing and checked and moved all connections, but after re-assembly the same problem exists.
  • NickRCarter Jan 10, 2008
    RLT1730. Same problem, sound but no picture, just interference. Seems to display the PC facility when the button is pressed by displaying a blue screen.
  • jmepoltcn Jan 11, 2008
    i have the n2750w 2005 model same problem
  • Roanyoat Feb 01, 2008
    My GoVideo TA2050 has no sound and no picture.
  • Anonymous Feb 19, 2008
    no picture but with sound .
  • magrosser Feb 19, 2008
    mine too, no picture but has sound
  • duhduh Feb 23, 2008
    I have no picture but the sound is find. All other components have the same issue, Wii, DVD player.
  • karlzinn Mar 04, 2008
    for all inputs no picture, only vertical grey bars (which don't change when I change inputs), almost like a "test pattern" but sometimes shifting in shade of grey.   sound is ok.  I have turned power off and back on several times.  I have left set on for an hour.
  • allenc5782 Mar 13, 2008
    Mine is white too. if i let it warm up a while it will turn on but then goes off. a piece on the power supply is buzzing. I took it apart and found no noticeable flaws. If its cheap enough try the power supply, I have a polaroid and its easy to remove. but theyre also cheap tv's.
  • Anonymous Apr 03, 2008
    While watching one channel we had been getting a "bleed" through from another channel. Now our screen is just black. We have sound just no picture. We have the Sony 42" KE-42M1 Wega Flat Panel TV. It is 3 yrs. old.
    While watching one channel we were getting a "bleed" through from another channel. Mainly on the left side of the TV. Now all we have is a black screen and sound.
  • zmason May 20, 2008
    same
  • dramig May 21, 2008
    Have dish; am getting the sound, but no picture.
  • grobnz Jun 23, 2008
    Also have Dish. Everything was fine for about 18 months with my Sharp Aquos. But now have sound, but no picture.
  • Anonymous Jun 23, 2008
    have sound but no picture
  • Anonymous Jul 05, 2008
    No Picture only sound?
  • mmasonlawyer Jul 20, 2008
    I have sound but no picture when watching a dvd - any suggestions?
  • Denine3 Aug 09, 2008
    Panasonic 50" 1080P plasa Flat screen. We have all channel except the HD channels. The HD channels have sound but no picture.
    Thank you
  • jurusam Aug 19, 2008
    Have an LG 32LC2R with no picture but sound ok. Gone has far as the oscillation/ inverter board and there is no power output there. Any solutions please.
    SJ
  • Anonymous Aug 22, 2008
    ultra30-500 no picture, has sound, solution?
  • Anonymous Sep 12, 2008
    Same
  • future1henry Sep 21, 2008
    no picture but sound is ok. picture flashes on screen when changing channels
  • jarinhunt Sep 27, 2008
    picture went out but have sound
  • inc1872 Oct 20, 2008
    same problem here . I bang on it any were and the screen flashes .
    I bet since I've had this TV for 18 months now that there is no warranty , that you can expect to pay $550 for a TV to work for only 18 months,
    So I'll wager that something inside wiggled loose and with no warranty I think I will pull it apart. I'll let you know
    Jeff
  • Anonymous Nov 05, 2008
    sane problem - replace backlight? although it woks when you first turn the TV on (for a few minutes) - replace ballast or the like?
  • missy trapp Nov 05, 2008
    I have the same problem. Sound is fine, but screen went black - no picture. The picture will come on after turning the TV off and back on - but will only stay for a couple of seconds or minutes.
  • Anonymous Nov 14, 2008
    I have sound but the screen is red. Close caption still works but I can't see the picture
  • bjwalz Nov 17, 2008
    I have the same problem. I was watching TV was night and the screen went out. I can hear the programming but see nothing. Any suggestions on how to fix the problem would be appreciated.
  • Anonymous Nov 21, 2008
    any fix yet, i have the same problem
  • estes03 Dec 01, 2008
    same issue. no picture but with sound.
  • heashfus Dec 01, 2008
    I have the 26" LCD with the DVD combo and I just literally bought it yesterday and we set it up and starting watching a dvd. As soon as I paused the dvd to get something, the screen went white and you still got audio. We've since then had it happen 3-4 times in the middle of the movie. What would cause this? This Tv is brand new!
  • don aldridge Dec 02, 2008
    Have 23" LCD Tatung -- good sound blank screen
    23 inch LCD Tatung -- good sound but blank (black) screen
  • davila83 Dec 03, 2008
  • nobody912 Dec 04, 2008
    going crazy, would not turn off, then sounds goes up by itself
    no picture ..TV 8 months old
  • heck75 Dec 13, 2008
    Sanyo 32in. DP32746 LCD Television Have sound but no picture flash when power botton pushed sound OK but no picture and no warranty could this be inverter problem DARFON MS10TVF VIT71008.60 LCDTV $179.99
  • colson18 Dec 19, 2008
    white picture and no sound. only had the tv 14 months.
  • Anonymous Jan 03, 2009
    I have owned this tv for 1 year. while watching picture went out but sound continues. BIG RIPOFF! need help to fix.
  • socalgerl Jan 10, 2009
    I have had my Vizio 42 inch plasma for about 2 and a half years and now only have sound and no picture!! Someone please help me
    Cheryl
    Problem Solver:
  • 6 Answers
Check the capacitors on the main powerboard. They are cylindrical and the tops look like they are a perforated X. If the X has popped up or broken than those capacitors need to be replaced. Also, compare your powerboard with one for sale on E-bay and note which capacitors have been changed (usually a different color; factory black; changed blue or orange)
I did this for my Akai 27" LCD TV and it works now. I changed 3 capacitors that were rated at 16v/1000uf to 24v/1000uf. Cudos actually belong to a Mr. Brown who I read about in a forum somewhere. Thanks, Mr. Brown...it cost me $5 to repair my TV rather than $135 for a refurbished powerboard.
Posted on Jan 18, 2009
Phillips {15pf9925/17s}
The same problem.Sound and no picture.There should be a fix for this problem.To many people having the same problem and are capable of unsoldering and replacement.If anyone knows which componet or components to replace alot of people would be real happy.It is always nice to repair yourself.Any help would be greatly appreciated,I'm sure by all. Thanks in advance. (kingfiss)
Posted on Apr 03, 2008
I am thinking that this probles is the LCD inverter card, I have the same problem but I can't obtain this card. Somebady knows or who has it.
Posted on Nov 18, 2008
This might be a possible solution instead of a complaint. First for those who has black screen and sound. Go to website: www.lcdparts.net, you may have to sign up. In here it will tell you that with this symptom you may very well have a defective inverter. It even tells you that you can change it yourself and doesn't require a very skilled individual to tackle it. The only problem is the backlight inverter module costs 179.00 bucks and thats the problem for me; just waiting to gather the cash so had not tried this fix myself. Good luck for those of you who are going to jump into this one.
Shannon
ps. If this is a solution for you, please email me to let me know, it may or maynot save me some cash or headaches.
shannon.okeefe@nf.sympatico.ca
Posted on Jun 18, 2008
Change the main board on the tv and you should be good!
Posted on Jan 31, 2008
Audiovox FPE3000 will not allow Comcast remote operation
Try to find out who really makes Audiovox alot of time a big company like maybe sony or rca or such may make a tv like that and try there codes as well
Mar 28, 2010 | Audiovox FPE3000 30 in. HD-Ready LCD...
No picture.
The problem is with the ic's which will have to be replaced to fix this problem.
Apr 09, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Sound but no picture
The first thing that comes to mind is that the brightness and contrast or turned all the way down. See if you can't turn them up. Otherwise it may be the backlight inverter or backlight itself. Most likely the inverter, sometimes you can tell by looking really close to the screen, if you can still see a faint image then the inverter needs to be replaced. Probably a job for a technician but that depends how comfortable you feel opening up the TV and ordering parts online.
Good Luck!
Feb 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
NO sound with Dvi/HDmi
Unplug the tv about an hour.Go in the menu reset the sound back to factory setting.Should work, if nothing wrong with ur Tuner signal board.
Feb 14, 2010 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox model FPE3000, has sound and picture but
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Need power supply for AUDIOVOX FPE3000 i see other people are having the same problem. any suggestions?
These power supplies are not longer being manufactured or hard to locate.
I could repair it for you if you are not able to DIY.
Write to jah2mil@hotmail.com for further details.
Sep 14, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Have audiovox fpe3000 no pic or sound.
First check to see if you have your 5v standy - a red or other color light should be lit on the front of the tv- also check to see if you can hear a clicking noise -comes from the relay on the main powersupply- listen as you press the power on button-if its totally dead- check your power supply fuse 1- usually a 3.2 a 125v- depends on power supply if its no good- some other component on the board may have caused it- either way need another power board
Jul 11, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
We have sound, but no picture.
Up to this point the HDTV has been working fine. However toda I tried to use theDVD, which has never really worked, and now I cannot tv picture. I left request by phone to call me but no call so far.
Oct 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
No sound no picture
that happen to me when i put the tv in the hop i found out it was the power adapter
May 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
No picture
Have same problem, sound no pic. My repairman said I needed an inverter board but he could not find one. The board is made by Darfon. I emailed them, got no responce.
Eddie
Dec 09, 2007 | Audiovox FPE3000 30 in. HD-Ready LCD...
Philips 42PF9731D37 42 in. HD-Ready LCD Television Logo
1,476 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
