Is there any way you can reset a 32inch tv when it is stuck on one channel and the remote wont respond either.
  • 3,741 Answers
If its stuck up on any channel.then unplug the tv directly from wall outlet.then disconnect all the external wires of the device connected to the tv at its back and then wait for 30 minutes then reconnect the power cord of tv only and check out changing the channels. but if it is still stuck up on same 1 channel.then its gone in stand by mode.and its the case of power board resetting.this needs to open the tv.then remove all the internal connections and reconnect this will reset the power board. but mostly this unplugging reset will help. check out. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 04, 2009
No remote. Channel stuck on #1. Wont change
Have you tried unplugging the TV..holing the power button for 30 seconds, then plugging the TV back in? That resets the TV. Also, if you can get into the menu and select TV..then auto scan..that might work. I would try resetting the TV first.
Mar 21, 2014 | Vizio Televison & Video
My Haire HL37E is stuck in the multimedia mode and wont respond to anything, what is my solution
get a niversal remote and use the codes for lg not for haier,,, once its programed (turns off/on) press last/channel button that`s it
Sep 08, 2010 | Haier HL37E 37 in. LCD TV
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Fujitsu P42VHA30WS Television
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
Top Televison & Video Experts
