Question about OKI B2540 MFP Printer
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX THIS ERROR?
Posted on Feb 12, 2010
  • wint3r Jan 03, 2013
    This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
Posted on Jan 03, 2013
MF F@X activities
Good morning my printer okidata B2540 mfp not work anymore because the scanner installed on my notebook windows 7, it prints, but lost all other functions. so ask for help. Att WGS
Jan 12, 2013 | OKI B2540 MFP Printer
I NEED TO INSTAL OKI B2540 MFP PRINTER ON MY
You can go here
http://www.oki.co.uk/support/printer-drivers/index.aspx
May 18, 2010 | OKI B2540 MFP Printer
How to install w/o the CD Rom
Go here
May 06, 2010 | OKI B2540 MFP Printer
How to replace a toner before it ends on oki B2540MF??
I know this may seem like an obvious solution, but have you read the manuel? If it's no longer in your possesion, you can download it directly from here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Alternatively, here's a link which shows you how to do it:
http://my.okidata.com/oki-faq.nsf/FAQCentral/18FE0A954455318585257656004A3BE4?OpenDocument
Hope this helps. If so, please rate. Thanks.
Apr 14, 2010 | OKI B2540 MFP Printer
OKI B2540 MFP .... Just in the process of setting it up. I have one problem: I have one telepone line that rings once for most incoming calls but for faxing purposes I have a second number on the same line...
You need to get an auto switch box such as the Command Communications Comswitch 5500 it was what is called distinctive ring and that if the function you need. You can plug in your phone, fax machine, answering machine, etc. You can get them from Office Depot, Office Max, Staples and such.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | OKI B2540 MFP Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Yes
Reinstall the fuser after its
connection connector is cleaned
Turn on the power supply again
If error still exists_
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI B2540 MFP Printer Logo
3,306 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
