Question about Pentair Minimax NT Heater
Our heater show's Eo4 never gets hot
Our heater hot tub SPA never get hot and show's temp EO4 and we change everything
  • Anonymous Mar 22, 2014
    On my L.A. Spa Oasis I am getting an error code which looks like 505 or S0s or 5U5 or SUS. It is hard to make out the code. Thinking that maybe an led is out on the middle digit. What does this code mean? I cannot use my hot tub :-(
    Champion:
  • 246 Answers
Lol but u never clean t burners
Posted on Sep 14, 2009
Heater Mini Max display the fault code EO4. What is the definition.
E04 is an airflow fault. You should hear the fan come on. If not, the fan is bad. If so, then your problem is electronic and beyond the scope of most DIY'ers
Apr 15, 2011 | Pentair Pool & Spa
I have a Pentair MiniMax NT heater. The fan does
if voltage to fan replace capacitor if no voltage check safety circuit
Aug 16, 2017 | Pentair Minimax NT Heater
What does error EO4 mean on a NT Mini Max Propane heater?
This is a fan falure code, it will mean your fan is out or the air pressure switch has a problem. Ether in the switch or the hose going to it. You can also check where the hose hooks up to the fan housing to see if anything is stuck in the port.
Feb 14, 2010 | Pentair Minimax NT Heater
Error code lo and eo4
The LO is just telling you the water is below 58 degrees. The EO4 is the fan sensor. If you haven't used the heater for a while you should check for rat and bird nests then you can check your air pressure switch to be sure it is OK. The NT LN model will have the gas pressure switch in the same circut, so if you have the low nox model be sure to check all your gas valves and be sure they are on. If this is a LP heater be sure your tank is at least 1/3 full to have enough pressure to run the heater. If the heater hasen't been run for a while be sure to bleed your gas line also. Good luck.
Dec 04, 2009 | Pentair Minimax NT Heater
E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Dec 03, 2009 | Pentair Minimax NT Heater
What is a eo4
ERROR CODE EO4 SAYS TAKE TAPE OUT AND REINSERT IT BUT TAPE WONT COME
Sep 10, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Power OK, can smell gas, but no ignition. Get the
The EO4 is listed as a Fan Failure. However, these heaters have a tendency to go EO4 for no apparent reason. It is what I call the "heater hic-cupping". The easiest thing to try first is to reset the heaters computer. To do this, you will open the right hand side door, find the POWER toggle switch and move it to OFF. Then turn off the Circuit Breaker to the heater,shutting down all electrical power to the unit. You will need to wait about 15 to 20 minutes before you do anything else.
After that time, revese the order. Turn on the Circuit Breaker, then the Power Switch on the heater. Try and start the heater. The computer will "reboot" flashing codes like --- or 888, do not worry about those. When the display panel comes back to normal, check what the heater is reading for a water temp and compare that to what the water is actually. Hopefully, they will be right on, or close, together. The heater will try to start 3 times before going into "Lock Out" mode.
If it does start, it was just the computer hic-cupping. If it does not start and you receive another EO code, on the backside of the Display Panel, there are Diagnostic Lights. If there is a light on by a couple of letters, like HLS or PS, then that is what is malfunctioning.
Jul 08, 2009 | Pentair Minimax NT Heater
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
HEATER GOES OFF ON EO2 OR EO4 CODE . WATER FLOW IS 145GPM HEAT EXCHANGER IS CLEAN FAN WORKS FINE. VENT PIPE HAS BEEN CLEARED OUT THIS IS A MINI-MAX 400 I RUN A FAN BLOWING ON THE HEATER AND IT STAYS ON...
EO4 is the heater fan error, it may go on briefly and then shut off after only a few minutes. most likely cause is a blown fan-there is a thermal switch installed on the blower fan that shuts off the fan when it gets too hot. the only workable solution is to replace the blower fan unit completely also 145 GPM is a very high flow rate; normal residential pools operate in the 40-70 gpm range and 110+GPM on commercial pools if this is residential you may have too much pump for your system. 1 1/2-2 hp is standard if you also run an automatic vaccuum off the same pump
May 07, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT Heater Logo
145 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
