Question about Avaya Computers & Internet
Placing a Forward Button on 1616 IP Phone
The switch I have is a IP 500 and IP Manager as the software v6.2(14).I'm trying to put a forward button on a 1616 Ip Phone with the 10 digit phone number programmed on the forward button so when it's pressed there's already a number set. Also there is another person who on the overflow list for that phone and when I press the forward button it rings 4 times and then goes to the overflow person and never to the forwarded number I have programmed. I tried almost everything on the button programming. Any Ideas Guys?
What you need to do is, set up a button that will turn forwarding on. then set a number in manager on the forwarding tab, set the number. If the number is going to change a lot, then you should set a second button up as, forward number. One changes or sets the number, and the other toggles forwarding on and off
Posted on Sep 06, 2009
An easy way to port forward my modem/router
1.Before Forwarding a Port Setup a Static IP Address
2.Open up the finder on your Mac.
3.Click the Applications button near the left of the page.
4.Click the Utilities button near the right of the page.
5.Click the AirPort Admin Utility button near the right of the page.
6.Select Apple Base Station from the Select Base Station list.
7.Click the Port Mapping button near the top of the page.
8.Click the Add button near the right of the page.
9.Forward Ports 80 on the Apple AirPortExtreme
Give the below values
PUBLIC PORT:80
Private Address : your static Ip
Private port:80
When you're finished, click Update near the bottom of the screen to save your changes
Mar 12, 2014 | Computers & Internet
Nokia 1616 2
Try to hard reset but first backup your files then add the write code.
Warning : Do not enter any wrong unlock codes on your Nokia 1616 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1616 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1616 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1616.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1616 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1616 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1616
Jul 02, 2013 | Nokia Computers & Internet
How to forward call to another phone
Press feature soft key (first button under display panel) and the 4.
In order to cancel call forward press feature key, # key, 4.
Jun 23, 2012 | Nortel Business Series Terminal T7208 -...
Using AVAYA IPO 500 R6 V2 IN 1616 and 1608
Check the IPO software is installed correctly and see if the most up to date software is installed, current software version 6.1 for this model.
Uninstall previous version or current version. Then Reinstall the newest version.(6.1)
Should take of any problems you are having with the phone. Since you have replaced it once, the problem lies in the software not hardware.
Mar 16, 2011 | Avaya 1616 IP Phone
How to forward to another phone
can you check either the display or the option itself if you have the Forward button? It might be there..
Jun 14, 2010 | Polycom SoundPoint IP 501 IP Phone
Polaris 500 sportmans and the 4x4 does not work in reverse
On mine the override button has to be pushed
Jan 03, 2010 | Polaris ATV
Call Forwarding
If you have access to the manager software for your system? you can select the user who's calls you wish to forward and set up and unconditional forward. If you don't have access to the Manager software you can do it on your phone with a couple of shortcodes, the default ones are : -
*07*N# - use this one to set the number you wish to forward to
*01 - use this to turn the forward on
*02 - use this to turn the forward off
Note these are only the default settings for and IP 500 system, they may be different on yours.
Apr 10, 2009 | Avaya 4602SW IP Phone
Trouble forwading a call on a cisco 7960
If your primary database is not up on Cisco Call Manager (CCM) then the phone doesn't accept any changes in configuration, all call functions work.
Feb 16, 2009 | Cisco 7960 IP Phone
Can i divert all incoming calls to a mbile phone?
Need to setup call forward external on your phone. Then you can program it thru your superkey button.
Dec 22, 2008 | Mitel 5212 IP Phone
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
169 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
