Question about Intel Motherboard
No matter what i do cd rom not detecting - Intel Motherboard
  • alc03 May 11, 2010
    is it the cd rom that is not detecting cd's or is it the mainboard that doesn't detect CDROM device ?
  • 797 Answers
A few things to check and do:
Make sure that the power cable is connected and tight.
Make sure that the IDE cable(if it is an IDE) cable is connected and tight. Some times the cable can work out of either the mother board or the cdrom.
If the computer still cannot see the cdrom, then go to the bios settings and see if it is set to detect the cdrom (the cdrom can be turned off in the bios settings). Also you could set the bios to default settings and then set what you want.
If you still cannot get the cdrom to detect, then the cdrom is suspect.
Replace the cdrom with a good one from a friend or if you have another one.
Hope it works.
Posted on Sep 04, 2009
    President:
  • 1,015 Answers
Is the cd-rom being detected in the BIOS menu? Have you checked the cd rom jumper slave/master settings are correct on the back of the cd-rom drive? Are you using a standard ATA cable or a cable select one? Have you tried a different ATA cable or serial ATA if it uses that? Are you using the cd-rom drive as a slave with the hard disk or is it a master on it's own IDE? Is the power connecter fully inserted into the cd-rom drive? Check for any BIOS updates from Asrock web site tha address this issue..They may have a BIOS update that solves your problem.
    President:
  • 392 Answers
Check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Fix DVD/CD ROM to work Acer M1610, Computer not detecting DVD/CD ROM. No drive is seen how to fix this, what are my options. OS is Vista
Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
MY dvd writer not detect dvd. but detect cd. this is dvd problem.
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope it helps
Aug 30, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Rom dos not red cd
First check to see if your CD-ROM drive is detected in My Computer.
If it is detected, it could be that your CD-ROM drive lens is dirty. You can clean it using a CD lens cleaner available on the market. The more risky one is opening your CD-ROM drive and clean the lens using a cotton damp in a little alcohol, it works for me.
May 27, 2011 | Computers & Internet
My sony CD Rom problem is that the computer is detecting the CD Drive but the CD Rom is not detecting the CDs
then you should clean you cd rom using a cleaner and stil if it doesn't respond you have to change the ROM
Mar 17, 2011 | Sony Computers & Internet
Bios does not detect cd rom drives, the cd rom drives has power but it does not work cause bios its not detecting it and it a new drive, my toshiba satellite is a85-s107 let me know if u can fix it.
I have a Toshiba Satellite L355D that would not detect the CD Rom in the BIOS although the Rom appeared to powered up and running. I traced the problem to a ribbon cable connector that was between the jack the CD Rom plugged into and the jack on the mother board. The ribbon cable plug at the MB had backed out and was only making the power connections to the Rom making the Rom appear to be operating.
Dec 05, 2010 | Toshiba Satellite A85-S107 Notebook
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
Where can i get driver
use things like driving detective or something. it automatically gives you updates for your hardwares that needs updates
May 20, 2009 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Toshiba Satellite A200-1M4 When I start my laptop i can hear a long peep sound and my DVD ROM auto opening. My DVD ROM PC detect but It can not read the CD always showing inset the CD. Please help me in...
dvd burners or rom drive have 2 lens inside, one for DVD read, the other for cd read. I see it often where one fails out in the drive but the other works. With one working fine and the other not, I would replace the drive. If still under warranty send it to manufacturer. If not do a search on Ebay for a replacement drive, or get a local laptop repair shop to do it for you.
May 11, 2009 | Toshiba Satellite A200-16J01D Notebook
MY COMPUTER DOES NOT SEE THE CD-ROM
my cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Dec 25, 2008 | Computers & Internet
CD ROM is not detect in My Computer
dtect your rom in bios
and try.
Apr 01, 2008 | Intel Motherboard
Intel Motherboard Logo
387 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
