Question about Intel D101GGC Motherboard
The SYSTEM process hiked to 100% usage after installing the VGA drivers. Please Assist me. Thanks in advance.
  • nani_sarath Sep 05, 2009
    Yeah I have seen it already...The process Image name SYSYEM username SYSTEM is using 100 CPU. I have read some where that it might be due to video card failure. Please help.
  • 62 Answers
Your problem is almost similar to mine but mine have an explorer.exe consumed my cpu a 100% usage that end up hanging. What I did is changed my explorer.exe to xplorer2.You can download a freeware for this at this link http://www.zabkat.com/x2lite.htm but the Pro version works best.Just be sure that it is your default file manager to avoid hanging up again.Hope this will help you.
Posted on Sep 17, 2009
    President:
  • 392 Answers
Check which process is utilizing maximum usage. for that to locate go to task manager, in that see process tab and locate the process which is utilizing the max usage. Right click the process which utilize maximum processor usage and end it.
Posted on Sep 04, 2009
Driver
please give more details of the driver you are looking for. probably indicate whether its inbuilt or an external vga card. also indicate the operating system you are installing it on and i will assist you.
Regards
Jan 02, 2011 | Vga (CAT5-1000S/R) (EXTCAT51000)
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Nov 25, 2010 | Computers & Internet
Mercury motherboard vga driver for windows 7
Here you are ,
http://www.mercury-pc.com/product-drivers.php?productid=644
If these are not windows 7 compatible then windows 7 will automatically install a Standard VGA Adapter driver.
Please rate my post!
Regards
1234s282
Apr 18, 2010 | Mercury P4VM800M7 Motherboard
Im trying to make a pivot version 2 animation a Gif but before it finishes it says out of memory and i have 4.77gb left in my memory
whats 4.77gb? a space of your hardrive or 4.77gb of RAM? check the requirements of the application if does match more than your specs of your CPU then try adding your virtual memory by go to system properties (right click on my computer and go properties) at the advanced tab, performance-settings, advanced tab, click change on virtual memory like 4096 for minimum and maximum and/or reinstalling the application.check on the task manager at the performance tab check your memory usage when using that application if your memory usage tops at 80%-100% you should end the process of other applications and background services that are not needed to run.if this not helps find a computer which is the same as your computer i mean same SPECIFICATION and install your application if that worked on the other computer then you have a problem with your Operating System...
Feb 21, 2010 | Computers & Internet
MSI RS482M4 Mobo not recognizes USB port on XP SP2-3 boot.
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Computers & Internet
Procesor usage upto 55% wen having opend single window
could point to both hardware and software issues..
but first check software issues. can be due to virus/spyware running.. check taskmanger and lists the processes by cpu % ... this will give you the process which is gobbling up the cpu cycles. make note of the file and track it down in hard disk. you will then have to research what it is for.
if you have a antivirus installled it may be possible that it is virus scanning the disc.
hope this helps
Aug 07, 2009 | Intel DG31PR Motherboard
My cpu usage is more ,transfer rate i.e coppying spee is low
hi,i think this is most likely just your os .files on harddrive corrupt.reinstall windows!
Mar 06, 2009 | Computers & Internet
Dual boot vista/XP on dell studio 1737, drivers needed ?
For the video drivers you might try the intel generic drivers for xp these should work here is the process.
For the audio use the latest vista driver and then follow the steps here.
The latest driver in combination with f you are using Microsoft Windows XP*, you may need to first install KB888111.exe, the Microsoft* UAA High Definition Audio Package version 1.0a. should work.
Jan 30, 2009 | Dell Studio 1737 Laptop
CPU Usage Meter 100%...... Indexing..... HELP!
What processes are you running?
Check taskmgr.
You will find there what is going on, and which program and processes are running on your computer taking the 100% CPU usage.
Dec 30, 2008 | Dell Latitude D430 Notebook
Veo advanced personal web camera
1st You download Webcam Driver. Veo Webcam Driver Free After this install the webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Jul 28, 2008 | Veo Advanced Connect Webcam
Intel D101GGC Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
