Question about LG 24 in. LDF 7811 Built-in Dishwasher
Top arm in dishwasher will NOT spin!
I've tried cleaning the arm - nothing in any of the spray holes. Taken off the back run of plastic that feeds the top spray arm - checked for obstructions. Checked the screen (replaced 3 weeks ago because dishwasher wasn't drying dishes). I've taken it all the way to the impeller and still can't find the problem. Also, added water after the initial drain on start-up thinking maybe there just wasn't enough water getting into the unit.
Can anyone suggest something I haven't done yet...besides throw it out into the yard?!
  • kpaller Sep 12, 2009
    I did disassemble down to the check valve (white plastic bit with two openings) didn't notice anything blocked up. Is there anyway to check the motor before calling the repair guy? Could it be obstructed anywhere else?
    Thanks for getting back to me - I'll keep you posted!
  • 423 Answers
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Posted on Sep 12, 2009
  • Jeff Meyer Sep 12, 2009
    The check valve is probably not obstructed, given what you have said.
    If you choose to pull the unit, invert it, remove the black support
    frame to get to the Vario motor, you could check the resistance of the
    motor to see if it is shorted. I don't know the proper resistance of
    the working motor, but if it is failed, it is probably shorted.
    Note that places like:
    http://www.repairclinic.com/
    allow you to return parts that you don't need, even if you have opened the package and installed it. Hope that helps.
    Please be careful if you decide to expose the motor, this unit is heavy and you must invert it to do this work.
Why doesn't upper sray arm work?
  • Improper loading or over loading of dishes and glass ware that blocks the spray arm from rotating; check your user's guide for proper loading methods.
  • the holes in the spray arm can be plugged from food particles or other debris, like coffee grounds; remove the spray arm and clean out the holes; run water through the arm to verify there is no blockage.
  • check to see if the spray arm became disconnected from the feed tube or the feed tube from the water inlet feed hose.; reconnect hose or tighten down on hose clamps
  • check for any filter blockages; remove food particles and debris
  • the tub itself could be under filling, because of a restricted water inlet valve; pour 1 to 2 quarts of water into the tub of the dishwasher and run it; if the performance improves, replace the water inlet valve with a new one; DO NOT try to repair the old valve- it will fail once it's taken apart and put back together.
  • the circulating motor drives a water pump that rotates an impeller, which creates water pressure to go through the washer arms and out the holes. The jetting action of the water pressure exiting the spray arm holes propels the arm to spin...if the water pump impeller is worn, damaged, or impeded by food debris, the cleaning action will be greatly diminished; inspect and clean or replace the impeller if necessary.
  • If the aforementioned trouble shoot and repair methods do not correct the problem, then a more in depth diagnostic check will have to be done by a qualified repair technician to check switches that controls the water/drain pump, (if it is a dual action model for example); to verify if the switch or the pump itself has failed.
Mar 24, 2015 | Dishwashers
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
The top rack dishes are not being cleaned properly. It seems that the water is not makeing it way throught the feed arm, hence not being feeding the spray arm.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 27, 2011 | Dishwashers
Hi there, My Bosch exxcel is playing up. the top arms are not spinning. So far i have purchaed new arms used several cleaners, taken the side of and checked the float and cleaned generally. The bottom...
Hi Mark,
Have you checked the seal/gasket on back of the upper spray arm assembly?
If you pull the upper basket forward the entire spray arm assemble will come with it. You can remove the spray arm assembly by releasing the single clip at the top at the rear of the basket. The spray arm assembly with then slide out backwards.
Once you've removed it, have a look at the back of it. There is a plastic gasket inside with 2 holes which fit over the studs at the top of the delivery tube still attached to the back of the dishwasher.
You can remove the back cover of the spray arm assembly by releasing the 2 clips at the top and bottom. Be careful here as they may be brittle after prolonged use of the washer.
Remove the back cover and take the plastic gasket out. Place the holes of the plastic gasket over the studs on the delivery arm in the back of the washer and check the gap between the gasket holes and the studs and check for excess movement.
If there is a significant gap or movement here, then it needs to be replaced. If there isn't a reasonable seal at this location, water will leak from there and there may not be enough pressure to rotate the spray arm
If you've already done this or there seems to be no problem with the gasket, please let me know and I will try to assist you further. Similarly, if this proves to be the problem and you need assistance obtaining replacement part/s, just let me know.
Hope this helps.
Regards,
BElectric
Dec 14, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Upper dishwasher arm not spraying water
Have you looked at the spray arm fixing nut at the back top arm as this has just gone on my machine
Sep 27, 2008 | Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
LG 24 in. LDF 7811 Built-in Dishwasher Logo
575 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
