Question about Magic Chef 9522 Electric Double Oven
Double oven - self or external venting
I have a MC double oven, model 97f4ez manufactured March 93 need to know if i need an external vent. Any help appreciated.
  • lbrokaw51 Sep 04, 2009
    Electric oven.
    President:
  • 2,923 Answers
It would be best to have a ventilation whether it's an electric or gas oven. Having an external ventilation would prevent the heat to reside in the kitchen. If you're asking for a suggestion, I would strongly suggest to have a vent. It's a good idea.
Have a great day!
Posted on Sep 04, 2009
    Brigadier General:
  • 5,158 Answers
Unless it is a gas oven i'm not sure that you would need to vent it outside
  • Roberta Smith
    Roberta Smith Sep 04, 2009
    further to this. there would be a sticker on the rear stating it needs to be external vented. you should be able to see a vent on the back or top if the manufacturer intended for it to be external vented as well
What is the year of my White Westinghouse harvest gold self cleaning oven serial number kuc 17050 model kf435tdgi?
According to the serial number this product may have been manufactured March of 1977.
Feb 27, 2015 | Ovens
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Mar 30, 2013 | Frigidaire 30 in. Electric Gallery Series...
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
Have an old MC oven seems like suddenly there is no gas coming through ? I used in a day ago
check regulators, and valves, on the regulator pay close attention to it's vent, (usualy a small brass bolt with a hole in the top) many times these vents become clogged with grease and other sediment, the easy fix is to buy a new regulator, the right fix is to extract the vent system from the regulator and boil it out.
May 24, 2011 | Magic Chef 9122 Gas Single Oven
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Do I need to vent to the outside?
Hello, No you don't need to vent outdoors, and YES all you need is a electrical supply. **I will add however, allow for an air cushion around the unit when it's installed in the wall as well as a vent or small gap with maybe a custom grill at the top. One of the most common service calls I get for self clean built in ovens is reseting or replacing safety thermostat's. Hope that helps Good Luck :)
Nov 01, 2009 | Ovens
I have a Thermadore double wall oven, M# C302ZS. The oven is reading F24. I put in a new whole front touch pad, and it's still reading F24. What can be my problem??
I've copy and pasted an exert from this ovens service manual. try this and let me know of the results.
Good Luck
F-24 or F-25 This is caused by close contact to the control panel for more than 60 seconds,
appears in display window such as someone leaning against the controls or objects hanging in front of
controls.
F followed by 2 digits appears Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn
in the display window it back on.
Oct 29, 2009 | Toastmaster Ovens
Desa International Self Venting Fireplace manuals
Try Googling (desa)(CGFB32CA)(manual) without parens.
Jun 30, 2017 | Ovens
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
Magic Chef 9522 Electric Double Oven Logo
156 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
