Question about iLO Televison & Video
My 23inch ilo tv wont change channels is stuck on one station and the remote wont help.
    Brigadier General:
  • 5,158 Answers
Unplug the set for about 15 minutes. this should reset it
Posted on Sep 04, 2009
My tv model #27F500T is changing stations all by it self
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
May 26, 2011 | Televison & Video
I have an ILO HDTV. I try to change the station with the remote but the TV only changes the station between 2 and 22. It doesn't respond to my commands when I want to place it on channel 3 for my...
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work.
The Poodle Guy!
Nov 21, 2010 | iLO 2600 Television
TV is stuck on one channel and won't change even with remote.
Ii would begin by changing the batteries in the remote. As they lose their power they will control some functions but not others. If that doesn't solve it, get back and we can take additional steps. i want to help.
May 23, 2009 | iLO 3200 32 in. LCD Television
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
T.v. remote codes
Yes the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.It works all the features.
Feb 27, 2009 | iLO IWT3206 TV
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Stuck on channel
Hello All,
This looks to be a problem either on the IR circuit board or in the microprocessor that controls these features and controls. I would suggest since you have tried to change channels from the TV itself that the problem in the processor is the more likely option. In this case I would say since this would involve a lengthy troubleshooting procedure, That you may have to take your TVs to a qualified TV repair facility for servicing since the procedure may be beyond just replacing a part, and may involve actual electronics troubleshooting. Having owned a shop for some time I can tell you that some items are only repairable at TV shops.
I hope this helps, Thank you, Shuttle83
Jan 05, 2008 | iLO 2600 Television
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
My tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
95 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
