Question about Car Audio & Video
My cd's are stuck in my 08 toyota camry and it reads error 3. what does this mean and how can I get my cd's out?
  • 4,963 Answers
It may be possible to tease out the jammed CD through the slot using another (old) CD.
If not, then the player will have to be removed from the dashboard, the covers taken off and the CD released from the mechanism.
Make sure you have the security code before pulling out the player
Posted on Sep 04, 2009
My 2007 toyota yaris shift lever is stuck on park, what could be the problem?
Shifter stuck in the Park position - YouTube
? 3:17
www.youtube.com/watch?v=-myhP6tRv4U
Jan 2, 2012 - Uploaded by iworkforbudlight
Short video on how to get your shifter out of park when it's stuck. This is for ... I'm assuming that's a Toyota ...
Shifting lever stuck in park - 2004 Toyota Camry - RepairPal
repairpal.com > Questions > Toyota > Camry > 2004 Toyota Camry
Aug 21, 2014 - my shifter got stuck in park,I read the book and read to take the little cover off by the shifter and push the botton to release the shifter. it worked fine ...Shifting lever stuck in park on 2004 Toyota Camry .... 2007 Toyota Camry ...Missing: yaris
Nov 05, 2015 | Toyota Cars & Trucks
How can I eject stuck 3 CDs from CD player + GPS 2006 toyota camry grande?
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
Dec 29, 2014 | 2006 Toyota Camry
I have a problem playing cd's in my 08 toyota 4runner
If the lable is stuck inside, the unit will have to be opened unless you are able to pull it out with a twizer or a long pin. Obviously it is coming in the way for CD to be read.
Feb 18, 2014 | Toyota 4Runner Cars & Trucks
My cd's are stuck in my cd player in my 2006 toyota avalon. error code 3
This type of malfunction usually requires removal of the unit and disassembly
Jan 19, 2013 | 2004 Toyota Camry
2010 Toyota Camry "Check CD" error
Yes, certain 2010 Toyota Camrys were involved in both the sticking accelerator pedal and the floormat recalls.
New Arrivals
Emergency power supply
Jan 15, 2013 | 2010 Toyota Camry LE
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
Toyota Camry cd player keeps giving me an error message (error 1)
If your CD's are not immaculate or tired copied / PC burned and non original you can get an error in reading. If the CD eventually plays after multipal enrties try a lazer cleaning disc . Good Luck
Apr 05, 2010 | 2007 Toyota Camry
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Stereo
it sounds like the cd cassette is stuck, we had the same problem on a JVC unit, we had to pull it apart, remove the cd and put it back together. this did work
Jan 24, 2009 | 2000 Toyota Camry
Car Audio & Video Logo
839 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
