Question about Singer 7462 Mechanical Sewing Machine
Singer 7462 sewing machine
So, I pulled out my sewing machine to sew some stuff together, and the foot pedal doesn't work. I haven't used it in probably a couple of months, and every time I have used it, I have had no problems. Well this time the plug end of the foot pedal easily slides into the machine, and doesn't really stay in all that well. Regardless, it doesn't work at all, as if the plug isn't going in correctly. Does anyone have any suggestions?? I am about 90% sure it does not have anything to do with the actual foot pedal.
  • ragdoll5 Dec 08, 2007
    Thank you for responding.
    I put the power cord in, plugged it in, and then put the foot pedal cord in, and out and in again (several times) and there was no beeping.
    The foot pedal cord is the kind with the metal prong at the end similar to the headphone prong. Generally when you plug those into something, it is snug, but my foot pedal one does not click when it goes in, and just about falls right out. I don't know if this happened before when it did work, though.
  • ragdoll5 Jan 12, 2008
    Actually, my step dad and I took apart the machine to look at the connection to see if it was loose, and it was. He bent it some which fixed it, but it is clearly only a temporary fix. Anyone can take apart their machine and do this if you have some small flathead screw drivers and a lot of patience. I will probably bring it back home and ask him if we can open it again and perchance replace that part, or come up with a more permanent solution. Thanks for y'alls input!
    Scholar:
  • 110 Answers
There is two seperate cords on this machine. A power cord and a pedal cord. If you put the power cord in and switch the machine on, and then remove the pedal cord it should give you a beeping sound, which shows you the connection does work.
Please give me feedback in order to help you
Posted on Dec 08, 2007
I have just discovered the exact same problem with my 7462. At first I thought that I had pulled the shaft of the foot pedal outlet still attached to the plug and lost it on the floor somewhere. However, I just spoke with a parts supplier who suggested that the plug no longer fit into the outlet snugly because the shaft liner had broken off and fallen down inside the machine. He instructed me to be sure to UNPLUG the machine so I would not electrocute myself. I then was able to use a flashlight and metal probe to find some loose parts just inside the opening for the foot pedal plug. Unfortunately, this will mean a trip to the sewing machine repair shop, but at least I can stop looking (in the vacuum cleaner bag, under every table...) for a loose part.
Posted on Jan 12, 2008
  • najma Dec 23, 2012
    this is exactly what happened to mine....how much will it cost to fix?
Singer electric sewing machine 2 01-2 know it didn't work no electricity going in to sewing machine.Is there away I check the power cord and how do you put together the foot pedal
for workshop manuals go google and type in --workshop manual for singer sewing machine 2 01-2-- and download the pdf version page
take the power lead and foot control to a sewing machine repair shop ( anyone) and have it tested
Oct 07, 2015 | Singer Sewing Machines
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 07, 2008 | Singer 7462 Mechanical Sewing Machine
Button Hole Beeping on 7462
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Sep 06, 2008 | Singer 7462 Mechanical Sewing Machine
Bobbin
To adjust any sewing machine for thin material do the following.
1.Use a fine needle,
2.Use a fine thread,(upper & Lower)
3.Reduce the the thread tension, Upper& Lower)
4.Reduce the presser foot tension,
5.Reduce the stitch Lenght.
6.Help the machine by pushing the material towards the needle while sewing. (don't pull it back.)
Apr 04, 2008 | Singer 7462 Mechanical Sewing Machine
I lost my power cord for the singer 7462 part # 77234
Best to contact your nearest Singer dealer, or try calling a nearby service dealership for any brand, as we quite often have used foot controls or even access to replacements, even the ability to make them up on occasion.
Apr 03, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
303 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
