Question about ASUS Computers & Internet
Asus Leonite2 operators manual
Need the Asus Leonite2 operators manual needed for transfer to new case, just incase i dont memorise the positions of the plugs
No did not, I have done the transfer successfully though.
Posted on Sep 06, 2009
2003 Silverado 4WD. Service 4WD dash light comes on after engaging 4WD and acts up by engaging itself randomly for several days, then goes back to normal.
Check connection at the 4X4 control module , check power and grounds . Do you know how to do basic electrical testing ? Does your truck have manual or automatic trans mission ? Which transfer case does yours have ?
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module (TCCM) starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position begins flashing to inform the driver that the TCCM has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been engaged. Once the new mode/gear position is fully active, the switch indicator for the new position remains ON constantly. In the event that the TCCM can not or will not complete the shift, the indicator returns to the previously selected position; this is a Transfer Case Shift Control Switch Indicator Flashes, then Returns to Previous Mode condition.
The NVG 263 transfer case provides the driver with 4 manual mode/gear positions:
• 2HI - 2 Wheel Drive high range
• 4HI - 4 Wheel Drive high range
• 4LO - 4 Wheel Drive low range
• Neutral
Have it check for DTC'S - diagnostic trouble codes ?
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0359
DTC C0379
DTC C0550
Your best bet would be take it to a qualified repair SHOP
Dec 28, 2016 | Cars & Trucks
2006 gmc envoy Denali 4wd will not engage
This vehicle had option of three different transfer case ! Which one of these is the one in your vehicle ?
Transfer Case - NVG 120-NR9 Transfer Case - NVG 126-NP4 Transfer Case - NVG 226-NP8
The New Venture Gear model NVG 226 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 226 provides five modes, Auto 4WD, 4 HI, 4 LO, 2 HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 lb ft of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, to enhance stability.
The New Venture Gear model NVG 126 RPO NP4 transfer case is a one speed automatic, active, transfer case. The NVG 126 provides only one mode, Auto 4WD, and is transparent to the operator. The active transfer case provides the benefits of on-demand torque biasing, wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features, such as flexible adapt ready position and clutch pre-load torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-7 N?·m (0-62 lb in) of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds, and provides higher torque biases at higher vehicle speeds, to enhance stability
The New Venture Gear (NVG) model NV120, RPO NR9 transfer case is a single speed, full-time, all wheel drive (AWD), transfer case that incorporates a front/rear drive differential carrier assembly.
Nov 19, 2016 | 2006 GMC Envoy Denali
Changed the dashboard switch for 4wd. That didn't work. Still cannot get into 4wd.
The New Venture Gear model NVG 246 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 ft lb of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 40 km/h (25 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, in order to enhance stability.
Mar 26, 2016 | 2004 Chevrolet Silverado 1500 Crew Cab
I can here the tranfercase locking in but its not turning front tires at all ?
Your vehicle had option of two different 4x4 systems ,
New Venture Gear 263 Selectable Two Speed Transfer Case
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached (or has been engaged). Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
The NVG 263 transfer case provides the driver with 3 manual mode/gear positions:
OR
The NVG 236/246 transfer case features a 4 button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has been engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
If there are problems with electronic part of the systems the shift control switch light will flash warning of a problem , If no lights you have a mechanical problem in the transfer case itself .
The front axle control circuit consists of an electric motor actuator which engages and disengages the front axle. The front axle actuator motor consists of a Permanent Magnetic (PM) motor, a worm gear controlled plunger, a front axle switch and an electronic control circuit all within the actuator assembly.
The front axle actuator has four circuits connected to it, a front axle feed circuit, front axle ground circuit, front axle control circuit and a front axle switch circuit.
Whenever a shift to AUTO 4WD, 4HI, or 4LO is requested, the transfer case shift control module engages the front axle by grounding the front axle control circuit through a current limiting driver. Test Description
The numbers below refer to the step numbers on the diagnostic table.
Tests the electrical function of the front axle actuator. Helps determine between mechanical and electrical malfunctions.
Tests for proper power and ground at the front axle actuator.
Tests the operation of the front axle control circuit.
Helps determine if the transfer case shift control module is able to monitor the front axle switch.
Tests the front axle switch circuit for an open or high resistance.
Measures the voltage between the front axle feed circuit and ground.
Tests the front axle control circuit for an open or high resistance.
Inspects the front axle for a mechanical malfunction.
Tests for open in the front axle feed circuit.
Feb 14, 2016 | 2001 GMC Yukon
Error message repair 4wd
I guess you probably don't know what transfer case you have ?
SERVICE 4WD
Refer to
Transfer Case Description and Operation in Transfer Case - NVG 149-NP3
Transfer Case Description and Operation in Transfer Case - NVG 246-NP8
Transfer Case Description and Operation in Transfer Case - NVG 261-NP2
Transfer Case Description and Operation in Transfer Case - NVG 263-NP1
The four manual mode, or range gear positions, of the NVG 261 transfer case are:
2HI - 2 wheel drive high range
4HI - 4 wheel drive high range, part-time
4LO - 4 wheel drive low range, 2.72:1 gear ratio reduction
N - Neutral, 4 wheel
Neutral
With the info I've given you ,you should be able too now !
There is probably a code stored somewhere !
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550.
Jan 31, 2015 | 2004 Chevrolet Silverado 2500
Wiring diagraM for hp a6120n
product specs are here
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=c01048279&lc=en&jumpid=reg_r1002_uken_c-001_title_r0001
motherboard is
  • Motherboard Name: [Asus] P5LP-LE
  • HP/Compaq motherboard name: Leonite2-GL8E
    HP motherboards specs:
    http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=c01080268&lc=en&jumpid=reg_r1002_uken_c-001_title_r0001
    You might try here
    http://www.ps2netdrivers.net/drivers/hp.p5lp-le/ for a manual which might tell you what you need to know.
    BUT this is the one. Apart from much other useful information it contains mainboard pin-out information for connection to the case (I think these are pretty standard anyway)
    http://www.ctechinfo.net/documentation/manuals/leonite_manual.pdf
    (The trouble is this is a motherboard made by Asus for HP. As such Asus do not provide any information about it whatsoever. HP information if you can find it is not sufficiently detailed)
    18.December.2014
  • Sep 26, 2014 | HP Pavilion A6120N PC Desktop
    Need to know positioning of detents in transfer case for Mazda B2500
    If you look at the flange and then on the case the positions these go in as clearly visible. The bolt holes and the pins locations are different
    Oct 04, 2012 | Cars & Trucks
    My 98 f150 was in 4WD Hi this morning when I started it. Selector switch is in 2WD position. 4WD Hi light is on, hubs (or front differential) is engaged and transfer case engage. (Feel front wheel hop...
    If the switch was in the 2WD position and the transfer case was locked in a 4WD range, my 2 SWAGs would be bad switch or the connector to the shift motor is damaged / corroded or the fuse to the transfer case shift relay module is blown ( fuse # 17 ) / problem with the transfer case shift relay module.
    This is without knowing if the truck was used in 4WD the night prior, and shifted out just before turning off. If this is the case, the shift motor might be stuck, and a few hits with a dead blow hammer to the transfer case might jar it free again ( do not use a metal hammer, it could damage the transfer case ).
    The vacuum shift solenoids on the firewall are controlled by the GEM ( Generic Electronic Module ) which is grounding either the 2WD or 4WD solenoid, depending on the shift plate contacts in the transfer case. ( when in 4 or 4H, the contact switch plate signals the GEM, which in turn grounds the correct solenoid ).
    Pulling the switch will not cause the transfer case to go back to a default position, the switch has a resistance level for each mode, and needs that value to operate the shift motor.
    The resistance values for the switch between the 2 dark blue wires:
    2WD - 4100 to 3700 ohms
    4H - 1050 to 1150 ohms
    4L - 380 to 340 ohms
    - find the wire locations on the switch, mark them and remove the connector to test the resistance.
    Just my opinion on the order :
    1. Check the fuses for the shift motor
    2. Try the old school shift method, back up ~ 50' put into park or neutral, and shift from 4WD to 2WD.
    2.1. This is to see if the transfer case shift motor is bound up, and reversing might release it
    3. Try hammering the transfer case with a dead blow hammer while someone shifts from 2WD to 4WD. You only need the key in the run position, if it happens quick enough after running the engine, the vacuum reservoir will still have enough vac to operate the solenoids. Don't chance running yourself over.
    3.1. If this frees up the shift motor and the vacuum has bled off, you can try starting the truck and shifting into 4H then back to 2WD to get the front axle to disconnect or manually vacuum operate the front disconnect motor by applying vacuum to the pink vacuum line on the shift motor on the front axle.
    Mar 05, 2011 | 1998 Ford F150 Regular Cab
    Where is the transfer case shift motor located on 2004 dodge dakota
    The transmission control module and the transfer case control module are separate parts. The transmission control module is mounted under the hood and controls only transmission functions. The transfer case control module controls only the transfer case, and is located inside the truck. If you remove the trim panel under the steering column you will find the transfer case control module mounted just to the right of the opening.
    The shift motor is located just behind the axle tube to prevent damage.
    There is a shift motor on the right front axle that is vacuum operated.
    The shift motor (1) is an electromechanical device consisting of a DC permanent magnet motor, a motor brake, a gear train and an analog position sensor. The shift motors' overall function is to move and lock a gear that moves the mode fork found in the transfer case. This allows the transfer case to be shifted electrically to multiple operating positions (4LOCK and AWD). The operating current of the shift motor under
    stall conditions is 30 amps maximum at 72° F with 13.5 volts, at the motor leads.
    OPERATION
    Shifting in the transfer case occurs when the shift motor brake is released and a Pulse Width Modulated (PWM) voltage is supplied to the shift motor by the Front Control Module (FCM). A linear analog position sensor located inside the shift motor, provides the FCM with the motors' angular, rotational position. With this information, the FCM
    continuously knows the motors' position, and therefore allows it to accurately control the motors' operation, including voltage polarity which is used to control motor direction.
    REMOVAL :---Note: New shift motor assemblies are shipped in the AWD position. If a new shift motor assembly must be installed, it will be necessary to shift the transfer case to the AWD position prior to motor installation.
    Raise the vehicle on a suitable hoist.Remove the front propeller shaft. Disengage the wiring connectors from the shift motor and mode sensor.Remove the front output shaft companion flange from the transfer case.Remove the bolts (Remove the Shift Motor and Mode Sensor Assembly Bolts) holding the shift motor and mode sensor assembly onto the transfer case.Separate the shift motor and mode sensor assembly from the transfer case. See fig below:-- helpmech_19.gif
    1 - TRANSFER CASE.2 - SHIFT MOTOR AND MODE SENSOR ASSEMBLY.3 - BOLT.-- This should help.Thanks.Helpmech.
    Feb 26, 2011 | 2004 Dodge Dakota
    Transfer case grinds truck only runs in 4wheel low nothing in 4wheel high or 2wheel drive
    Manual or electronic t case?
    Section 07-07: Transfer Case, 4x4 System, Service 1994 Bronco/Econoline/F-Series Workshop Manual
    DESCRIPTION AND OPERATION Electronic Shift Operation The transfer case is equipped with a magnetic clutch, similar to an air conditioning compressor clutch, which is located inside the transfer case adjacent to the lockup collar. The clutch is used to spin up the front drive system from zero to vehicle speed in milliseconds. This spin-up allows the shift between 2-high and 4-high to be made at vehicle speeds listed in the vehicle owner's guide. The spin up engages the front lock hubs. When the transfer case rear and front output shafts reach synchronous speed, the spring-loaded lockup collar mechanically engages the mainshaft hub to the chain drive sprocket and the magnetic clutch is then deactivated. Shifts between 4-high and 4-low can only occur with the transmission safety switches closed. The vehicle's speed must also be within specified limits as determined by the transfer case speed sensor (3 mph or under). Electronic Shift Control System
    This system consists of a two-switch control system, an electronic control module, an electric shift motor (7G360) with an integral shift position sensor, and a speed sensor. Switch Control System
    There are two control switches located on the upper right corner of the instrument panel for fingertip shift control. The two switches are mounted horizontally and are identified as "4x4" and "LOW RANGE". Two indicator bar lamps are located in the instrument cluster.
    When either of the two switches on the instrument panel control are depressed, the first thing that happens is that the electronic control module receives input from the transfer case shift position sensor to verify what position the transfer case is in (2H, 4H or 4L). Next, the electronic control module looks at the speed sensor and the park/neutral position switch or clutch pedal position switch (depending on transmission type). If all conditions are correct to allow the desired shift, the electronic control module will tell the electric shift motor to execute the shift. After the shift has been made and the electric shift motor is off, the control module again looks at the shift position sensor to make sure the proper shift has been accomplished. Finally, the dash indicator light and the pushbutton light on the control panel will be illuminated by a signal from the electronic control module indicating the desired function has been completed.
    Electronic Control Module
    The electronic control module, located on the passenger side, controls the operation of the transfer case in response to inputs to the pushbutton control by the vehicle operator, the speed sensor, shift position sensor and the park/neutral position switch. Speed Sensor
    The speed sensor, mounted on the rear of the transfer case , tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur. Shift Position Sensor
    The shift position sensor, an integral part of the electric shift motor , tells the electronic control module the shift position of the transfer case . Electric Shift Motor
    The electric shift motor , mounted externally at the rear of the transfer case , drives a rotary helical cam which moves the 2W-4W shift fork and 4H-4L reduction shift fork to the selected vehicle drive position.
    Nov 12, 2010 | 1994 Ford F250 Supercab
    Computers & Internet Logo
    525 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
