Washing machine SAMSUNG WASHING MACHINE MODEL 7.0KG , WA700SCJ When pressed the start button,the sequence should be 1. water in 2nd. start washing. but my problem is When pressed the start button, 1. water not in 2. water drained out(should be after wash) 3. start spinning. how to solve this problem? tq
  • bro burris Dec 08, 2007
    close door and jigger wires
    Problem Solver:
Wont spin
Posted on Dec 08, 2007
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Water is blocked inside the machine
The warning buzzer should have sounded after 15 minutes with a warning code of "5E" on the display, if the machine has recognized the fault. Check the drain hose height reaches 90-100 cm as stated in the manual. Set the machine to spin only cycle and minimum water level:-
Press the FUNCTION button four times.
Press the START/HOLD button once.
Spin drying goes on for 11 minutes.
(When the FUNCTION button is pressed during spinning,
the spin time can be changed to from 1 to 7 minutes.)
If this doesn't work try repeating spin and reducing the height of the drain pipe gradually 10cm at a time.
Operation manual available here: http://www.nodevice.com/download/user_manual/samsung+wa80b2s.html
Good Luck.
Jun 08, 2014 | Samsung Washing Machines
I have a problem with a samsung wahing machine model WA95V3. No power coming on water solenoid valve when you switch on the push button,No error coming ,all the function is on.
you will find the solenoid is probably faulty and shorted out that part of the module, cheapest fix is to swap the hoses over at the taps and then select hot wash and cold water will come through the hot solenoid
Mar 08, 2014 | Samsung Wa95v3 7.5kg Washing Machine For...
Hello Dear, My Samsung Washing Machine Model:WA700SCJ;water is not supplied and says 1E what should I do/ any parts to be replaced. Regards Hashim4413@gmail.com
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 30, 2011 | Washing Machines
Im erik, from the philippines..our samsung washing machine model WA90FA has a problem..it hung, it cannot be turned off without pulling the plug..it cannot auto restart.literally hung..where can i find its...
Kumusta po?
Here's the owner's manual:
http://downloadcenter.samsung.com/content/UM/200607/20060731094411578_FA-PJT_AG_02154A-GB-cms[1].pdf
I'm familiar with the reset sequence for US Samsung washers and that is:
Unplug the machine for at least one minute and plug it in again.
Press and hold together the 'POWER', 'DELAY START', and 'SIGNAL'.
Paalam na po.
Good luck from Detroit, MI, USA.
Jun 11, 2011 | Samsung Washing Machines
No water enters Frigidaire GLTF2940FS1 Washing Machine when run
You will want to contact Frigidaire and ask them the sequence.
Dec 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a samsung J1043 7kg washing machine, apon usage of it, i get an error half way threw its washing stages. on the digital screen a message 3E pops up and then im stumped, i have drain the machine,...
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Mar 17, 2009 | Samsung Washing Machines
Hotpoint washing machine Aquarius WD640
Try this sequence; Hold down start and cancel button together, TEST should disappear of display,
Then hold down START/ CANCEL, and ON/OFF at the same time.
The message D/off should appear in the display, it should then work.
If it does not then the main pcb is likely to be faulty..
That will mean calling an engineer.
Pleas rate my fixya solution.
Thankyou.
Feb 07, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
615 people viewed this question
Top Washing Machines Experts
