Question about Epson Stylus Photo R300 InkJet Printer
Does not print text
Hi, My printer was working fine then it wouldn't print at all. I tried uninstalling and re-installing. Now I got it printing just graphics in color, but no text. It was printing text a little then faded out. Then the words were very faint and jibberish. Called Epson they had me change printer usb port and cleaned nozzles 3 times but it got worse. They said I probably need new headers??? Then gave me deals on a new printer. Do you have any ideas? Should I go shopping for a new printer? This one is about 4 yrs. old. thank you.
    Scholar:
  • 54 Answers
Hey there thedeligirl,
It does sound like hardware problem. If the hardware is 4 yrs old, and the people at Epson recommend you go with a new printer, then it may be time to head to wal-mart =).
The only thing I could suggest, is run some kind of calibration, or "clean headers" option on the printer.
Posted on Dec 08, 2007
Why is some of the printed text overlapping?
If the text on the screen is ok
It is usually du to a wrong driver installed.
uninstall your printer and reinstall it, and make sure you chose the EXACT model when you install the drivers
Apr 12, 2016 | Office Equipment & Supplies
My printer will not print. It prints a test page fine, but will not print any other documents
hi,
  • Check the status of your printer by moving to printers and faxes on the start menu.
  • Is it checked?Are there any queued print jobs?
  • Turn off both the printer and your PC.Remove the usb connections.
  • Unplug them completely from power.
  • After a few minutes connect them again.
  • Try to print.Cant print?
  • Uninstall printer[hoping you have installation disk] and install it again.
  • Make sure the selected ports on pc and printer correspond.
  • After installation restart your pc.
  • Now you can print!
Sep 20, 2011 | HP Photosmart C3150 Printer
My Lexmark x4690 all-in-one printer is not printing. It prints if I go through the touch pad menu on the printer and print an alignment page but not if I try to print anything from my computer. Text,...
You may need to uninstall the existing X4690 driver first before installing it's driver for Windows 7. Follow the instructions in this artricle on How to Uninstall Lexmark Printers. Once driver is uninstalled, reboot pc when prompted. Reinstall using the driver for Windows 7 from the Lexmark website at:
- Lexmark X4690 Driver for Windows 7 32-bit - Lexmark X4690 Driver for Windows 7 64-bit
Hope this helps.
Feb 25, 2011 | Lexmark X4690 Wireless InkJet Printer
Printing labels from SAP ECC 6.0 using smarforms, label prints however the printer commands themselves are showing on the label, not just the information the print commands are to control. Is there...
Hi there
Does this printer connected with your computer? If yes, there is a problem on printer driver. You need to add new printer with same name and if this successfully installed, you can delete the old printer icon.
When there is errors message or wrong command of printing, the usual problem is corrupted driver.
Another way to correct this is to uninstall and reinstall the printer driver if the first solution does not work.
If still not working, try this download and install the print diagnostics software. It will helps you to find and fix errors in the windows registry. Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Click on the blue text PRINT DIAGNOSTIC UTILITY and it will download automatically. Unzip it to install to your computer.
I hope these solutions solve your problem. Regards.
Feb 09, 2011 | Zebra RW 420 Thermal Printer
Hp 6310 show offline wont print
Hi, how do you connect to the printer? USB/parallel/Network? Does it prints fine if you print an information page from the printer display/butons? I would try to uninstall the printer driver and install it again to start. It's definately a communication problem so it may take a few tries to get it to work again.
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp5550 not printing
The first thing you need to do is make sure you have the correct driver so that you can re-install your printer. Then you need to go to your Start Menu and select Printers and Faxes. Delete any printers that you don't use or no longer have, plus any instances of the Deskjet 5550. Go into your Start Menu and select All Programs. Look for the Deskjet 5550 and put your mouse on it. Look for the Uninstall link then select it. Once it has finished uninstalling the program restart your computer. Insert the CD that came with your printer and follow the instructions. Your printer should now be re-installed and working. I hope this helps you solve your problem. Good luck!
Carol.
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Printer stopped printing color images
hi im josh in cebu phils .friend may i help you? The problem appears on your print out is a symptoms of software corruption. Try to re install new software driver for printer. but dont forger to uninstall the old one before installing a new. check also the printer port connection. good luck hope i helped you.
Mar 14, 2009 | HP Photosmart C7280 Laser Printer
Prints Gibberish, not the Text - Epson Stylus 460
This is usually due to a corrupted driver. To fix this uninstall the printer using the Windows uninstall software facility on the Control Panel (I am presuming it's a Windows system, if not use the uninstall facility of your OS). Reboot the computer then re-install the printer. If you need more help with the uninstall/re-install processes, report back.
Feb 01, 2009 | Epson Stylus Color 460 InkJet Printer
Printing text
Hi-
Try uninstalling and reinstalling the driver for your printer.
Hope this helps
Nov 02, 2008 | Epson Stylus Photo R220 InkJet Printer
Will not print text
wow..that's really and truly weird. you open to a shared screen service call? send me an email through my profile
Feb 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
