Keating Instant Recovery 14BB  Deep Fryer
Problem for Keating Instant Recovery 14BB (NG) Deep Fryer
Bought a four basket fryer on an auction.\r\nIt is
By ballou354 on Sep 04, 2009
Bought a four basket fryer on an auction. It is a Model bb14, serial m25860 not sure if it is now Lp or NG.
Pilot lights for both sides but does not light burners.
Can hear the click on the thermostat.
Steve
Best Solution
posted on Sep 04, 2009
Helpful)
muebe
Rank: Guru
Rating: 90%, 273 votes
Natural gas and LP gas run on different pressures. If it has been set up to run on LP and you hook it up to natural the burners will be very small and may not light due to LP works on a higher pressure than natural. If it is set up for natural and you use propane the flames could be way overgassed. One thing to check is what the appliance regulator spring is set for. There will be a cap on the regulator and when you remove the cap there is usually a small metal ring inside that sets the spring tension by flipping it's position. On top of the ring it will say NAT or LP. Now if you find this ring set on NAT then the appliance was probably running on Natural Gas and vice versa. If it is set up for LP and you go to Natural than the orfices can be drilled out and the appliance regulator tension cap flipped. If it is set up for Natural and you go to LP than it is best to replace the orfices with LP ones.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Keating Instant Recovery 14BB
Questions and Unsolved Problems for Keating Instant Recovery 14BB
Do you recommend Keating Instant Recovery 14BB (NG) Deep Fryer?
Answer
Answer
I have an Oster Cool Touch Deep Fryer. I want to clean the oil reservoir...is there a way to remove... (More)
Answer
The Lid on My Rival Model Number CZF725 won't stay closed
Answer
how does lid stay on one side locks the other does not
Answer
need a cord for ge deep fryer model number 168946
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Deep Fryers Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
