Question about HP Photosmart 3210 Printer
Printer can not print scan kopieing gives me a code Oxc18a0406
Fuser unit reset
my maccine no kopis and disply a-150 light updowen
Jan 31, 2013 | Kyocera Mita KMR-1810P Laser Printer
CANON PIXMA SCAN CODE 2,151,44
I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
Canon MP492 Cannot write or read file Code: 8,252,1 Please explain!
My canon MP 492 printer scanner gives will not scan documents and gives me the message 8,252,1 cannot scan. I can still print and copy, just not scan.
Dec 16, 2010 | Canon Computers & Internet
My hp c7250 gives me an ink system failure Oxc18a0406 message. is there any way that I can service it myself?
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 09, 2010 | HP Photosmart C7250 All-In-One Thermal...
My printer does not work cause oxc18a0406 . what
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 22, 2010 | HP Photosmart C5180 All-In-One InkJet...
Bij het maken van een kopie kopieert Hij Alleen het onderste rechter gedeelte, dus een kwart van de originele .
Hallo,
Bij selecteren van de kopieer functie op de printer zelf, zal slechts een
kwart van het papier worden afgedrukt: het gedeelte dat rechts beneden / voor op de glasplaat wordt gelegd.
De druktoets functie kopiëren op de printer staat op een vast formaat voor foto afdruk 4 x 6 inch (ongeveer 10 x 15 cm).
Voor het maken van een kopie van het gehele glasplaat oppervlak gebruik de software Dell Takencentrum van deze printer onder:
Start® Programma's of Alle programma's® Dell Printers® Dell AIO 810 ® Dell Takencentrum.
Meer hulp nodig ? Voeg commentaar toe in deze probleemstelling.
Feb 18, 2010 | Dell 810 All-In-One InkJet Printer
Printer error oxc18a0406
Kindly do the following steps to resolve the issue:
A. Press and hold the "*" key.
B. Press the "#" key and release both keys.Display should say "Enter Special Key Combo"
C. Press and release in sequence the "1", "2" and "3" buttons.
D. Press and release the right arrow button until the display says "System Configuration Menu".
E. Press and release the "OK" button.
F. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status".
G. Press and release the "OK" button.
H. Display should say "Hardware failure status: Clear. Press OK to clear".
I. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
J. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
K. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
L. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
M. urn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. If it didn't it's ok.
N. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2010 | HP Photosmart 8250 InkJet Printer
Troubleshooting in scanning and printing
You have to reset that cart. before you fill it there should be instructions on how to do this on the refill kit you bought, you cannot just fill the cart and put it in the printer you will dmage the print head if you have not already done so. I cannot see what was done so I could not give you a solution but only tell you that the ink needs to be charged before you put it into the printer!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
