Question about Canon MX700 Office All-In-One InkJet Printer
I cannot fax ineed to know at what speed should i set the emission and also wich feeder should i use because it is not clear ly illustrated on the screen wich one i am using at the moment
Hi! You can try an internet fax service. I use Popfax.com and it's easy, cheap and efficient! On FAQ page you'll find more information about it.
<img src="http://www.popfax.com/img/faxmailing.gif" alt="" />
Posted on Sep 07, 2009
    President:
  • Canon Master
  • 1,447 Answers
Please you follow your product user manual
Posted on Sep 05, 2009
  • Sazeed Computer
    Sazeed Computer Sep 05, 2009
    please you follow your product user manual
Our fax machine will only fax 20 pages from memory is there a way to clear the memory? We fax about 60 pages every night so this has become a big issue.
You include no details about your fax machine.
However, Are your faxes from paper copies only? Do you have to print them out to fax them.?
IF SO.. then you should use a PC fax card, to fax directly from a PC. If you have hard copy only, then the addition of a scanner, with a document feeder to speed things up, will enable you to do same thing. Should be able to que up all the faxes and walk away.
Nov 10, 2010 | Office Equipment & Supplies
Uf-770 how do you stop the received fax and delete it? 900 page fax that I need to delete
Open the toner door
Turn the machine off
Open the document feeder
While holding down the pointed switch by the skinny glass turn the machine on ...hold down switch until you hear a beep...close doc feeder
Clean out any jammed paper by opening the toner door
Scroll down to ALL JOB CLEAR
press SET
wait for the machine to initialize
Jun 10, 2010 | Panasonic Office Equipment & Supplies
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Bypass feeder on lexmark printer c524 is not working or else how to use the bypass feeder
Here is a very good described and illustrated article about how to use the bypass or MP Feeder on the Lexmark C524. http://bit.ly/bmKEVT
Feb 11, 2010 | Lexmark C524 Laser Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Laserclass 9000l
When the problem occurs what does the display say?
Jun 01, 2007 | Canon LaserClass 9000L Plain Paper Fax
Canon MX700 Office All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
