Question about Yamaha DV-C6280 DVD Player
The dvd is stuck mid way not opening or closing
The dvd player is stuck mid way not opening or closing
    Sergeant:
  • 217 Answers
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Posted on Sep 04, 2009
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
DVD is stuck. open close button does not work. Is there a solution to this problem?
yes..... you need to unplug (power) the player for 10 - 15 mins... plug back into wall, but when you do this press the stop/open/close button (because the player will try to load the disc).....
good luck
Jan 21, 2011 | Memorex MVD2042 DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Dvd door stuck closed
Take the DVD player hold it tight in ur hand and give it a couple shakes,to losen stuck frame or the plastics warp.Plug it back in to see the DVD player drawer open and close now,not take the DVD player aparts check,if the the motor or the rubber band,not a dead motor or broken rubber band.
Jun 25, 2010 | Oritron DVD600 DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Jul 04, 2008 | Philips Televison & Video
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Yamaha DV-C6280 DVD Player Logo
197 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
