Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I replaced the in cartridge and it still wont print it still says replace ink cartridge,
    President:
  • Brother Master
  • 1,447 Answers
You must be reset ink counter
Posted on Sep 05, 2009
  • mapsno Aug 19, 2011
    Your ship are belong to us.
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
  • 3 Answers
SOURCE: WONT PRINT AFTER REPLACING INK CARTRIDGE
There is a step missing from the book and HP's site. This how to has the answer, once and for all...
How to fix the repeat alignment issue with Hp All-in-One printer
Posted on Feb 01, 2009
Remag1234
  • 387 Answers
SOURCE: REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
Posted on May 05, 2009
meanlean28
  • 10 Answers
SOURCE: HP deskjet 920C replaced both ink cartridges and now it prints in
How do you clean the ink reservoir?
Posted on Jan 22, 2010
Replaced black ink cartridge, ink wont come out
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
Nov 07, 2017 | Brother MFC-465CN InkJet Printer
My print cartridge light wont go off and it wont print nothing what should i do
I think ur printer cartridge ink is finished. Other wise the cartridge circuit is dear.Pls replace ur ink cartridge .inform me result
Jun 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
I installed the drivers for a canon pixma mp210 and it wont scan. it keeps saying " E 1 6"
"E 1 6" error code means Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jun 11, 2011 | Canon PIXMA MP210 InkJet Printer
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
May 05, 2009 | Office Equipment & Supplies
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
