Question about Panasonic DMR-ES10 DVD Recorder
All I get is Remote DVD3 what ever button I press.
I have tried every button on the remote, and on the set and all I get is Remote DVD3.
  • Panasonic Expert
  • 244 Answers
Try pressing button number 1 and enter on the r/control
Posted on Sep 04, 2009
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
My Sony RD-VX525 DVD Recorder got set to DVD1, is there any way to set it back to DVD3 so I can use the remote again?
On the remote press the System Menu botton when opened, press Enter and scroll down to Option and press Enter then scroll down to Command, press enter and you'll find DVD1,DVD2 and DVD3 scroll down to it press Enter set or reset your unit as desired!
May 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Panasonic DVD Recorder DMR EX95VEBS remote control only displays DVD3 how can I reset this to get back to proper functions?
Dear FixYa
Thank you for your support. I have solved the problem on my DVD Recorder by reading other peoples solutions to this problem. My DVD display was showing DVD3 and all buttons would not work. So on the handset I pressed the ENTER/OK button and no. 3 button together for a few seconds, this cleared DVD3. I was so pleased that this worked. croneruk, 6/10/2008
Oct 04, 2008 | Panasonic DMRES15 DVD Recorder
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Mar 07, 2008 | Sony RDR-GX355
Panasonic DMR-ES10 DVD Recorder Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
