Question about HP Photosmart C7280 Laser Printer
My c7280 will not give me an accurat readout on ink levels. it says all are OK, but also says 0% on all colors
Reset ink level photosmart c7280
you go in under settings on your computer to do this ,afyter thi ink has been changed
Jul 27, 2012 | HEWLETT-PACKARD Photosmart C7280...
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
Experiencing a problem with an HP Photosmart C7280 All-in-one printer, after the yellow ink cartridge was replaced a 'change the cartridge' screen comes up when trying to print, even though the printer...
You may also try this: Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Then press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then power it off and back on.
May 11, 2010 | HP Photosmart C7280 Printer
Ciss ink won't work on hp c7280
Must use included HP "starter ink" cartridges before the CISS can work. There's a 3-button sequence [OK-Cancel-Black Button] sequence when powering on that will reset the printer and bypass the "starter ink" wall you're hitting
Jun 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Ink Level
The obvious solution is to buy Canon ink cartridges. If you don't care about an accurate readout, buy cheaper cartridges and swap the chips. I'd suggest keeping spares on hand and change them when one color stops printing.
Dec 18, 2007 | Canon PIXMA MP510 All-In-One InkJet...
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email steve@nicesites.org and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Laser Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
