Question about HP PSC 1510 All-In-One InkJet Printer
HP1200 not used for a year. now it doesn't print
I have a HP Business inkjet 1200. I was away for one year ..now
the printer mechanics seems to be ok..but it is not printing ..
the ink is not coming out.. I changed the cartridges ..
I have not changed the printheads? should I do this?
but if the printheads were not working properly shouldn't the lights
be blinking?
My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Nov 16, 2009 | HP Inkjet 1200dn Printer
HP business inkject 1200 won't print footers
Make sure you have the correct page size in the software.
I don't think this printer will allow you to print in the last 12mm of the page as it needs this to hold the paper while printing.
Feb 11, 2009 | HP Inkjet 1200dn Printer
Trouble with HP Business InkJet 1000
ur check all the sensor one bye one indivisual in dislpay scareen error code are different .mpost probablity this error front cover.
Jan 19, 2009 | HP Business Inkjet 1000 - Printer - colour...
Printing black only on a HP business inkjet 1200
File>print>preferences>services>open hp toolbox>configuration> select on black print cartridge in drop box>apply
Dec 14, 2008 | HP Inkjet 1200dn Printer
HP1200 prints blank page
Try ressetting the printer:
Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer
Jun 28, 2008 | HP LaserJet 1200 Printer
Helo from sheikh john
Please visit www.hp.com look for download, driver menu. Type the model you are looking for. If not listed use the nearest model series like hp1200. Other means, use simulation printer driver but you have to refer your manual the exact simulation printer. Hope this gives you hint.
Best regards,
Rosener
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP PSC 1510 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
