Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
EMachine monitor quit
My LCD monitor suddenly decided to quit working. There is power at the AC adaptor (green light is on) but nothing happens when I push the power button on the monitor.
Any ideas?
  • PullinDbls Dec 08, 2007
    I swapped my monitor with one from a friends computer. It works fine on my computer, so my video card is OK. My monitor wouldn't work on his computer, either. The power/video cable is integral to the monitor, so I don't know if I could replace it. There are wires going from the power button to the small circuit boad on the side with 4 menu buttons. How could I test this to see if this board is the problem not allowing the power to continue to the monitor?
  • 33 Answers
This could be one of three components:
1. The video card
2. Video Cable (cable from the monitor to the computer)
3. The Monitor
The way I would determine this is:
I would try to plug this monitor into another computer that you know works with other monitor. If this is a home computer and you don't have another computer to test this take it to a friends house. Use a different cable to connect the to computer and power if possible. Then switch out to the old hardware (e.g. power cable, video cable.) If all has been determined to work then it's probably the video card.
If you can do this at all I would suggest trying a new video cable they are cheap. Usually 10 bucks at the most or borrow on from someone else. If this is a DVI cable they are a little more expensive. VGA cables look like this btw http://www.networktechinc.com/cable-pc.html
Posted on Dec 08, 2007
  • Scott Calafiore Dec 09, 2007
    In order to test this board you would need an digital ohm meter and the board specs to see if the correct wattage is coming into the board and going out. If you can't get a hold of the spec just check to see any power what so ever is flowing out of the board. You can also visually inspect the board to see if any thing has blown like a capacitor. This will usually smell like burnt popcorn when it happens. This link should help you identify blown capacitors since they are the main source for building the power to run the monitor itself.http://www.pcstats.com/articleview.cfm?a...
I was given ThinkPad 2647 T22 and it has been in it's case for 1 year. I plugged it into the AC adaptor and the green indicator light came on that the battery was charged after 5 hours. When I pushed the...
Remove the battery and try to power on without it. Replace the battery if the computer powers on. If not, the motherboard have to be repaired/replaced.
Aug 15, 2010 | IBM ThinkPad T22 2647 Notebook
Monitor wont come on.green lite on the switching adaptor is off.Is the adaptor bad or monitor bad? How do I get a new adaptor?Model # WDS048120
The lamp on the power supply adapter should be on the minute it is plugged onto the AC outlet without the DC plug connected to the monitor, if it is not on then the AC adapter is bad, you can check the DC voltage with a digital meter. Post back so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | X2Gen MG19MY 19" LCD Monitor
My Neovo E-W22 monitor quit working. I have had it just under 2 years. It is as if it is getting no power. Any ideas?
Make sure the power connector is secure with your monitor and the adapter power light is on as green. If not working at all then just contact with AG Neovo as service.us@agneovo.com for 3 yrs warranty repair. But you probably have to cover the one way shipping only.
Mar 17, 2010 | Neovo AG H-W22 TFT - H-W22 22 inch LCD...
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Black screen
I'd reseat the memory first. If there are two pieces, take first one, then the other alone in the system. Possibly bad memory. If that's not it, the lcd cable could be unplugged. Try connecting to an external monitor. If that works, it's the lcd somewhere.
Good luck
Nov 22, 2007 | Compaq Armada E500 Notebook
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
107 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
