Question about Dell Dimension 3100 PC Desktop
LAN Connection Have a sky modem- but the LAN light keeps flashing same on new modem---and i can't get online--i eventually did succeed but only after i altered the duplex speed from auto to 10Mbps- but the normal green light on the modem is orange, so although i am getting on line something is still not right
  • 106 Answers
The orange light in ur modem is due to the suscribers network problem and low signal
Posted on Sep 04, 2009
Unable to connect to the internet
possible reasons why you can't connect to the internet
1. Ethernet cable is not plug in tight from the modem to your laptop. 2. DSL light on your modem is RED/flashing green/ OFF 3. if you have router try to unplug both modem and router for 20 seconds then turn your modem on first and wait for the DSL light on the modem become solid green before powering the router ON 4. check the LACAL AREA CONNECTION. it might be disabled. to check click satart menu then go to control panel then look for network ana internet then click network and sharing center. From the left had side of the page look for manage network connection and click it then check if the LAN is disabled. if its disabled right click the LAN and select enable. 5. check internet connection again if it works
Sep 10, 2011 | Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Acer Travelmate 250 wireless problem
Dear carlosdperez,
When you try to connect to the internet, you must create the new internet connection first, this because you use the difrerent hardware or modem to connect to the net. All you have to do is configure the new connection use your UK SKY Sagem modem and fill all the required input include your dial up number and so on. This is HOW:
Start Menu>Connect To>Show All Connection>Create The New Connection>>>> Follow the wizard>PRESS Next>Connect To Internet>Setup Connection Manually>Choose your Hardware/Modem (UK SKY Sagem Modem)>Use Dial Up Modem>Enter Your Connection Name>Enter Your dial-up Numbers>Enter Your Passwords>Confirm>DONE.
Since it succeeded, you should see the new connection on Start Menu>Connect To>>>
Good Luck!
Best Regards,
bionic23
Nov 05, 2009 | Acer Computers & Internet
I can get local access but not internet connection. I have cycled the power on both the cable modem & Belkin wireless router. I can get a lan cable connection from the modem directly to my laptop the...
if you connect the modem directly to your computer, Does it work ?
If you are not able to go online when connected directly to the modem then you will need to call ISP.
If you are able to go online when connected to the modem only then you will need to check the settings of the router.
Click Here for more info about routers
Oct 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Modem light is blinking no internet light
hi, there are two ways to assit you on this issue.Either you can call belkin customer care which is a TOLL FREE no. on the product box and get assisted or else proceed with the following basic steps.
1. the product that you have is an obsolette.
2.Before troubleshooting the belkin product. Please connect your computer directly with the modem (without router)on the ethernet(lan) port and check for the solid lights on the modem after turning it on, after that check for internet connectivity, if you can go online, its fine else you need to contact your modem vendor and get fixed.
3. if u can go online, then connect your router isolated port to the modem amd your computer back to the router's lan port(port 1) and check for the solid internet,power,modem,lan lights on the router.
4. if all are solid lights , check you can go online else you can hold the reset button at the rear side of your router for 2 mins if you have a cable modem and then check for connectivity.
5. If you have a dsl connection , then better contact customer care, they assit you very well.
Sep 21, 2009 | Belkin (F5D6230-3) Wireless Router
XP wont connect to internet through Sky Sagem Router
NO Internet
· reinstall drivers first including the network adapters.
· power cycle the modem and router (turn-off the modem and router, and wait for 10-15 seconds before powering on the modem first, then wait for 3-4 solid lights before you turn-on the router; check a website, or else
· bypass router (by directly connecting your computer to the modem)
· checked a website
· checked the IP address by clicking start button for winXP, click run and type cmd, on the c:> prompt type ipconfig then hit enter, get the IP: if the IP address starts with 169.254.x.x…the type ipconfig /renew…or else type first ipconfig /release, then type ipconfig /renew.
· If media is disconnected, check the modem cable that runs at the back of the computer, unplugged and plug it back, or try other cat 5/ modem cable.
· Check the device manager for network adapter (is properly working), by right click on my computer, click on properties, and click on hardware tab, and click hardware manager button, click the plus sign next network adapters, makes sure there is no markings such ? ! or X marks, or else install the device manager for the Ethernet card.
· Type Ping google.com, check if the it receives and sends packet, if it does, then check the browser…
· Check browser settings, delete cookies, temp files on general tab…(click on tools->internet options), click on the connections tab, the make sure it is “never dial a connection”, check the LAN settings, make sure that there is no marks or checks on the boxes..click ok. Click on the advanced tab, click on the button “restore defaults”. Hit apply and ok. Close the browser, and open it up again and check for online website.
· Once connected, install back the router, if the there is no website shown, please your router brand support line for the reconfiguration of the router.
Apr 27, 2009 | Computers & Internet
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
MOTOROLA SB5100
Online Flashing - Scanning for a network connection.
On - Startup process complete. Modem aqcuired.
This means that your modem is not locked onto your cable providers network
Jun 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My wireless connection keeps going on and off
you have to connect your computer first directly to the modem to test if you'll get the same problem hook to it. if same problem occurs you have to call your isp or whoever gave you the modem to have it reset or reflashed.
May 22, 2008 | Linksys Wireless-G WRT54G Router
LAN problem between Belkin modem and P5P800-VM MoBo
When you connect the pc to the router does the port number where that pc is connected is there any light on it? if there is check the IP address of the pc.
Click Start>RUN>type CMD click OK>type ipconfig on the command prompt if it says disconnected try changing the ethernet cable.
If you already receive a IP address that's good then try getting online.
May 03, 2008 | ASUS P5P800-VM Motherboard
Dell Dimension 3100 PC Desktop Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
