Question about Gateway FPD1530 15" Flat Panel LCD Monitor
When I turn on my Gateway FPD1530 Monitor, it turns on for just a couple seconds in Power Saving Mode then turns off. Will not stay on or go into full screen. I checked all the connections.
  • 105 Answers
Replace one or two 1000uf electrolytic capacitors in the power supply.
Monitor Mike
Posted on Oct 17, 2009
  • 335 Answers
The monitor may be fixable. Your problem is likely either the power board, or the inverter board. Since you get an image for a few seconds, the problem is not likely to be the lcd panel itself or it's embedded backlight. Check with the manufacturer first to see if it's still in warranty.If not, replacing the boards will fix it, but might not be worth it in the long run. See if Gateway has these parts available, and how much it will cost. The parts shouldn't be very expensive, and it is easy to replace them. Other than the lcd panel, these boards are the only other parts in your monitor. Try the inverter board first, they are usually very inexpensive (power board not so cheap).
Your only other option is to replace the monitor......sorry. Post a comment and let me know how you make out.
Hope this helps!
Posted on Sep 04, 2009
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Why power saving mode shows up on monitor when my computer shuts down?
because the monitor is going into hibernation until the computer tells it to come back on
Sep 19, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
I have a black computer screen
hello
is HDD light is blinking on Computer when it is working ? if so , computer is working and you are having video card issue or something wrong with the monitor.
Feb 27, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor comes on for a second then goes off. Power light stays on
You say you can still see the screen if you look close enough. The only thing that gives it more light is the backlight. It is either shorting itself out right after it comes on or the device that powers it (usually the inverter) is the culprit.
Jul 23, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
My Gateway FPD1530 will not turn on
replace c106 and c107. fixed 3 monitors back to back, all worked like new!
Aug 27, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway monitor fpd1530
There are multiple curcuits for this model.
Quick turn off of the backlight can be caused by deteriorated solder connectiond on Q6 & Q10 on the power supply/inverter board. Resolder and reassemble. (board mfgr: BI Electronics)
Monitor Mike
Aug 05, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
908 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
