Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
My hoover bagless windtunnel has no power
My 2 yr old Hoover just had this same problem and I figured that it was from over use, but I love the vacuum so I ordered the same vacuum and i just opened the box and plugged it in and there is no power. I tried changing outlets and still no power. Now I own 2 hoovers with the same problem.
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
juststinks
  • 98 Answers
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
  • 199 Answers
SOURCE: My hoover U5720950 windtunnel bagless vacuum loses
when you lower the handel it is pinching the vaccume line constricting suction
Posted on Jun 11, 2009
carlsbiz
  • 1124 Answers
SOURCE: Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
  • 18 Answers
SOURCE: hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Posted on Oct 08, 2009
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
We're is the relay button?
Hoover warranty relay Vacuums Questions & Answers - Fixya
www.fixya.com > Forum > Tags > warranty relay > Vacuums
Hoover vacuums warranty relay related questions and answers. Ask your Hooverquestions. ... Vacuum off/on switch has play ... is, but sounds like you need a ... Question about U8341-900 WindTunnel 2 Bagless UprightVacuum. 1 Answer .
Nov 04, 2015 | Hoover U8341-900 WindTunnel 2 Bagless...
The brushroll stops turning.
Hoover Windtunnel Self-Propelled Vacuum Belt ... - YouTube
? 2:54
www.youtube.com/watch?v=AJL9McF7MAU
May 22, 2012 - Uploaded by Crucial Vacuum Fits: Hoover U6423-900, U6425-900, U6425-920, U6429-900, U6430-900, ... U6616-900, U6617-900, U6625-900, U6626-900,U6630-900, ...
Aug 06, 2015 | Hoover U6630-900 WindTunnel Bagless...
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
Can not figure out how I have to attach the Powered hand Tool
Just got connected it to the main hose and press the switch on
Mar 28, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
248 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
