Question about Frymaster Dean Kitchen Appliances - Others
Can light pilot, but when I release to turn it on, pilot goes out
    President:
  • 1,015 Answers
Make sure that the pilot flame is making direct contact with the thermocouple. You may want to try to use a lighter to provide direct heat to the thermocouple and when you push the pilot reset button you should be able to feel it grab when releasing the button(it may take a minute or two). If the ASO still does not hold after applying direct heat to the thermocouple and you have good pilot/thermocouple impingment it could be the thermocouple. Usually fryers of this type use a standard thermocouple but some systems involve a pilot generator. If it is not the thermocouple it can then be a bad mag head(not very common) and will require a new gas control assembly from frymaster.
Posted on Sep 04, 2009
2 Suggested Answers
SOURCE: Pilot light will not stay lit
I just fixed the same problem by replacing the thermo-coupler. 6 bucks at the H depot, shhhwinggg, hot water again.
Posted on Apr 19, 2007
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
How do I light my janitrol ucs100-55 heater?
you need to turn on the gas supply. then turn the button on the valve to the "light" position. now press down that button repeatidly until the pilot light lights, when the pilot lights you will need to hold that button down for about 15 seconds. then when you release the button the pilot should stay lit. when it does... turn the button to the "RUN" position. thats it... turn up the thermostat and the heater should kick in.
Jan 06, 2015 | Heating & Cooling
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
Williams heater model 3509612
Hold the button for 30 seconds, then release. If it goes out right away, you have a bad thermocouple. If the unit does not sense that the pilot light is lit, all of the gas is shut off, including the pilot light.
Dec 19, 2012 | Williams Heating & Cooling
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Mar 12, 2009 | Heating & Cooling
Open Questions:
Kitchen Appliances - Others Logo
556 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
