I want enclose my outside unit,not completely,just around it. How much space do I need to leave between the unit and what I enclose it with?
You should never cover your a/c condenser "
Posted on Sep 04, 2009
How do you use a flower loom?
You can use flowers loom to make a gorgeous DIY Flowers.Flower making is an easy craft to master and we'd like to show you how it's done. Here are the detailed information: http://www.craftstylish.com/item/9958/how-to-make-flowers-using-a-vintage-flower-loom/page/all
Sep 07, 2014 | Garden
How much room do I need around my Keg Cooler if I install it in an enclosed area?
you have to leave enough area around the unit for the heat to escape from the area, check the direction of air flow on the condenser and allow that to escape as far as possible, you can't block the airflow.
Jul 05, 2011 | Danby DKC645BLS Compact Beverage Cooler
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
I have a danby portable air conditioner with no manual. The picture shows two ducts going outside. My question is why does the intake go outside?
On a portable a/c unit the cooling is done by taking heat out of the air inside and dispensing it outside.
That's accomplished by washing air over the heat coil in the unit, then the air goes back outside to let the heat out there.
You'll need inlet air, and outlet air to accomplish that.
Inlet air is cooler as it comes in, then that air absorbs some of the heat inside the space you're cooling and turns around to go back out leaching heat outside.
Most likely scenario.
There may be another need for outside air revolving around positive pressure inside the conditioned space.
Let me know if that doesn't solve your situ.
Russini
Oct 30, 2010 | Danby Heating & Cooling
I need to know if I could insulate the unit bellow
You can insulate it, fiberglass is the best material to use. Make sure not to obstruct the T&P valve operation, and leave the space open where you can get in to relight the pilot/ service the burner assembly. That space is also the combustion air intake for the main burner, so you must leave it open.
Apr 12, 2010 | Smith A.O. SMITH Cyclone XHE Natural Gas...
My receiver shuts down frequently , wakes back after 2 or 3 sec .
do you have sufficient space around the unit? If it is in an enclosed space, has other components on top, etc, you may be overheating the receiver. Once it gets too hot it can potentially cause the issues you mention above.
If you have other components on top, try moving them to another shelf or below the receiver, and if you have a door on an entertainment center, leave the door open to help with air flow.
Jul 29, 2009 | Yamaha RX-V663 Receiver
Can I mount a window unit with no outside access
You could/can, but don't forget that (a) there is a good chance of heavy condesation, so size pan appropriately, or drain...and (b) The enclosed space where the drip pan is, is going to get quite warm. Hope this helps
Jul 13, 2009 | Frigidaire FAC124 wall/Window Air...
I have an Ascot wall hanging hot water heater.The wind frequently blows out the pilot light. Can I make a safe housing around it to protect it from wind and rain
Yes you can, but make sure that it has access to air. Leave at least 6" of space between the shelter and the pilot. Is it outside? I've never seen one outside.
May 29, 2009 | Water Heaters
How to put freon in?
Warning: It's a federal crime for anyone not EPA certified to charge a unit.
With that being said,The charging ports are located on the outside unit,You will need the proper set of gauges,an outside ambient air thermometer,a jug of refrigerant,an adjustable wrench,and the proper size allen wrench.
You will need to attach one end of the yellow(center) hose to the tank(leave the valve on the tank closed for now) and leave the other on the gauge manifold,Attach one end of the blue hose (left)to the suction line(the big one) and leave the other attach to the gauge manifold,Attach one end of the red hose(right) to the high pressure line(The small one)and leave the other attach to the gauge manifold.You will then need to take the temperature around the unit(ambient temperature)once this is done,you are ready to charge the unit.
You will need to remove the brass cap on the charging port,Insert allen wrench and slowly open the valve,the pressure on the gauges will rise to the current pressure,You will now need to start the unit and let it run for about 5 minutes or so,until the pressure stabilizes on the gauges.With the temperature from earlier you can begin charging the unit,but without me knowing what the temp is I can't tell you what pressure to charge it to,So the remaining steps cannot be completed.
May 16, 2009 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
