Question about Nokia 1208 Cellular Phone
Remove my security lock - Nokia 1208 Cellular Phone
    Sergeant:
    Champion:
  • 212 Answers
HI, You have to type in security code of your phone in order to log into the phone.... By default the security code is 12345 and if you have changed it, you must be knowing.... BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
Posted on Sep 04, 2009
When truck is idling sometimes doors lock 97yukon what can it be dont wanna get locked out
Either disconnect the auto lock security system or remove the power door lock fuse. Go W / the security disconnect .if it makes you uncomfortable. Its a standard feature w/ most security systems. Good Luck, Frank M.
Feb 21, 2016 | Cars & Trucks
I would like to reverse the door on my Zanussi ZDC68560W dryer
REVERSIBILITY OF THE DOOR
Proceed as follows:
    1.Remove the screws which secure the hinges to the cabinet (fig.A.1). Remove the door.
    2.Remove the screws which secure the hinge hole masking plates (fig.A-2) and fit the plates to the holes to which the hinges were previously fitted (fig.A-1).
    3.Remove the canister.
    4.Remove the work top.
    5.Remove the left- and right-hand panels.
    6.Remove the front panel hole cap (fig.A-4). To do so, squeeze together the anchor tabs which secure it to the cabinet.
    7.Remove the screws which secure the door interlock (fig.A-3) to the cabinet and remove the lock.
    8.Detach the connector from the door lock.
    9.Remove the tapes from the wiring (fig. B) and separate the wires for the door lock from the remaining wires.
    10.Re-tape the remaining wiring.
    11.Insert the general wiring harness into the support(s) positioned on the duct (fig. C) and position them parallel to the front panel so that they cannot come into contact with the drum. Attach to the anchor using a wire tie.
    12.Insert the door lock connector between the drum and the canister container, then remove it from the position shown by the arrow (fig.D-1).
    13.Insert it beneath the front brush cover (fig.D-2), secure to the anchors on the duct (fig.D-3), and remove the wiring from the other side of the cabinet.
    14.Insert the door lock connector and secure with screws to the front panel (fig.E-5). Ensure that the wiring is not trapped between the door lock and the front panel.
    15.Check that the wiring is routed through all the anchors released when removing the door lock wiring.
    16.The excess section of the door lock wiring should be secured using a wire tie to the wiring cover (fig.D-6). Fit the masking cap into the hole from which the door lock was removed (fig.E-4).
    Dado
25637655-hcssld2gpo2sm22yg24xoxcy-3-2.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-5.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-9.jpg
Apr 09, 2015 | Zanussi Dryers
My phone is locked and I can't open it and I want to turn it on to where I can go to internet and call please help
Do you mean the security or network unlock?If it is a security lock then you can unlcok it by using default codes like 0000 or 1234.If it is a network lock then you can get the unlock service from and remove the network lock permanently.
Feb 23, 2014 | Cell Phones
My Nokia fone is locked. How to open?
Is your phone Network locked or Security locked?
If Network locked,You can use unlock code to unlock the network lock of your Nokia . If it is Security Locked, then to unlock security lock try the default security code like 1234 or 0000 or 12345 . If those didn't work then you can use master reset code to reset your Nokia . It will reset your phone, removing any security locks(except network locks) .
If your phone is old model Nokia phone then you can get the Network Unlock code and Master Reset Code for free from Unlock-Free.com .
Jun 11, 2013 | Cell Phones
Nokia 2600 recover security code?
If you want to recover the security code of your Nokia 2600 you need to try the default codes 0000 or 1234. Otherwise get the Master reset code for free at Unlocking4Free.com and remove the security lock. After this lock is removed you can assign a new lock code for your mobile and use it.
May 29, 2012 | Nokia 2600
My security code for keypad lock i forgot...i want to open & i want to use back but i forgot what code i use before..
To remove the security lock,get the master reset code from here
Simpleunlocking.com
and reset from security Lock or password Lock.
Aug 08, 2011 | Nokia 1600 Cellular Phone
Error code 41
The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the door lock/switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly
to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock/switch assembly out of the front panel then
disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly (part #131763202) to address the problem if the washer works fine with the door switch bypassed. If not, replace the control board.
Jul 18, 2011 | Frigidaire ATF6700FS Front Load Washer
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
What is the special tool called for removing the ring so i can take that plate off to get at the screw that hold my ignition switch on my 1990 gmc 1500
You will require a steering column lock-plate tool to compress the spring-loaded lock-plate and then you can remove the lock-plate securing ring using either snap-ring/e-ring pliers or by using two small screwdrivers to pry the lock-plate securing ring off of the steering shaft. Here are some images to assist you, and at most auto part stores you can purchase a lock-plate tool or rent one, and some will even loan them to you if you have purchased a part from them, and also note in the image that the lock-plate securing ring is being removed using a screwdriver if the proper snap-ring pliers can not be obtained. It might also be necessary to remove the screws securing the turn-signal switch and position it out of the way to access the ignition tumbler retaining screw, and let me know if you require any further assistance.
Oct 24, 2010 | 1990 GMC Sierra
Locking with security code
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to 12345
Feb 10, 2009 | Nokia 5200 Cellular Phone
Nokia 1208 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
