Question about Lexmark All-in-One Printer with PictBridge
Lexmark X2500 I changed the color cartridge with a brand new one but every time I try to print something it says that the color is low and to order a new one and replace the cartridge, i take the cartridge out and put it back in do an alignment and it still says there is no ink and color does not print.
  • Anonymous Dec 18, 2007
    I've had the same problem. The only thing that seems to fix the problem is installing another new cartridge. I've gone through so many color cartridges since July, I could have bought a whole new printer (which I'm planning on doing soon!)
  • Loadmat Dec 25, 2007
    Same exact problem now- Time for a New Brand of All In One - any suggestions besides Lexmark or HP Al In One?
  • 48 Answers
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts) while installing the carts choose the option "new carts"
Leme know if this has helped u
Posted on Jun 18, 2008
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    My documents will not print the colored part. just Black and white
    I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
    Your Lexmark has two cartridges, one for colors and one for black.
    To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
    Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
    To order print cartridges:
    1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
    2 }}--> }}-->Click the Contact Information tab.
    3 }}--> }}-->Click Ordering Ink and Supplies.
    For help installing a cartridge, go to How to install the print cartridge.
    Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
    Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Lexmark printer always want a new cartridge
    What you need is to reset the ink level:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Hope this help.
    YBC (/\)
    May 28, 2009 | Lexmark X2500 All-In-One Printer
    Hope this help.
    YBC (/\)
    Feb 18, 2009 | Lexmark X2500 All-In-One Printer
    A light on my computer won't shut off
    well..these happen when the printer cartridges are changed, AND the print clean/alignment are not conducted.
    Aug 07, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
    Mar 25, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark All-in-One Printer with PictBridge Logo
    90 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
